checking to make sure my STEP_SCALE is correct
- travis036
- Thank you received: 32
13 Mar 2021 22:52 #202161
by travis036
checking to make sure my STEP_SCALE is correct was created by travis036
trying to remember from values i knew quite a while back...
my steppers are 1.8deg (200 per rev).
lead screw is direct drive, 5mm pitch, but my machine is in inches.
my stepper drivers are set, i think, to 1/8 microstepping (Leadshine DM542E, set to 1600 steps per rev).
my INI has STEP_SCALE values of 4063.9999 for all axis, but the machine is slow, so i want to verify. i have run the calculations so many times that i think i have forgotten how to calculate it...
so if i have this right: (8/1.8)*360*(5*2.54)= 20320 STEP_SCALE?
thanks in advance for this math help!
~Travis
~Travis
- Thank you received: 7468
13 Mar 2021 23:05 #202162
Replied by tommylight on topic checking to make sure my STEP_SCALE is correct
200X8=1600
1600/5=320
That will be steps per mm, so multiply by 25.4
320X25.4=8128
1600/5=320
320X25.4=8128
The following user(s) said Thank You: travis036
- travis036
13 Mar 2021 23:09 #202164
by travis036
Replied by travis036 on topic checking to make sure my STEP_SCALE is correct
wow, i was way off!!!
Many Thanks!!!
~Travis
Many Thanks!!!
~Travis
Time to create page: 0.082 seconds
