Spindle speed tuning
- mooser
- Thank you received: 15
28 Mar 2021 11:22 #203914
by mooser
Replied by mooser on topic Spindle speed tuning
Still poking around
This line (from the other thread), crashes on load so I commented it out. From what I can tell "net spindle-vel-fb-rpm" might be a 2.8 only thing so that should be ok that it's not there
#net spindle-vel-fb-rpm <= hm2_5i25.0.encoder.00.velocity-rpm
But down below in the spindle section I added the line (again from the other thread)
net spindle-vel-fb-rpm => abs.spindle.in
Shouldn't that cause a problem (doesn't but why not?)
M
M
- Thank you received: 2177
28 Mar 2021 12:19 - 28 Mar 2021 12:24 #203916
Replied by Aciera on topic Spindle speed tuning
Note that the syntax is this:
net <signalname> <= OutputPinName => InputPinName
(There may be more than one => InputPinName)
So this:
means that you are telling the system to create a signal and you want that signal to be named spindle-vel-fb-rpm and then you want that signal to hold the value of the OutputPin "hm2_5i25.0.encoder.00.velocity-rpm"
Note that the signalname is something you as the user chooses freely so it does not depend on the version you are running. The OutputPins and InputPins on the other side are predefined by the system an can vary from one version to another.
So if you copy/paste hal lines from other files you may need to change the signalnames to fit your hal.
[edit]
If the above line gives an error but this one:doesn't, then my guess would be that the signal spindle-vel-fb-rpm has been asigned to an other OutputPin somewhere before in your hal.
It is usually good practice to post the actual error as that makes things a lot clearer.
So this:
#net spindle-vel-fb-rpm <= hm2_5i25.0.encoder.00.velocity-rpmmeans that you are telling the system to create a signal and you want that signal to be named spindle-vel-fb-rpm and then you want that signal to hold the value of the OutputPin "hm2_5i25.0.encoder.00.velocity-rpm"
[edit]
net spindle-vel-fb-rpm => abs.spindle.inIt is usually good practice to post the actual error as that makes things a lot clearer.
Last edit: 28 Mar 2021 12:24 by Aciera.
- mooser
28 Mar 2021 12:45 #203918
by mooser
Thanks for the explanation (you know I didn't realize that the first set was just the variable name, thought it was something pre-set in axis/linuxcnc...... D'uh)
Looks like I've actually made things worse somehow anyway. Put my timing tape on the actual spindle and it seems I'm slightly farther off with these changes than I was before so I've put the old HAL back in and have to admit I'm just not making any progress understanding the way the "guts" are working.
Putting my operator hat back on and leaving the code alone.... (at least for now
Thanks again
M
Thanks again
M
Time to create page: 0.210 seconds
