Limit Error Dialog
  • Project_Hopeless
  • Project_Hopeless's Avatar Topic Author
  • Elite Member
  • Elite Member
31 Mar 2021 15:33 #204235 by Project_Hopeless
Limit Error Dialog was created by Project_Hopeless
I had a limit error during a cut the other day and I was wondering why the message did not identify specifically which limit for that joint, (+ve or -ve) had the fault.
I'm running Axis with a MESA card and each individual limit is wired to it's own I/O point. Does it matter that I am using the limits as Home switches?
02 Apr 2021 20:40 #204555 by andypugh
Replied by andypugh on topic Limit Error Dialog
If only one limit input is triggered, even if a home is triggered too, then the system should tell you exactly which axis and limit was triggered.
Unless it was an electrical issue that triggered more than one limit at the same time?
Time to create page: 0.176 seconds
