Homing setup
18 Apr 2021 16:00 #206312 by CaspianCmonster
Homing setup was created by CaspianCmonster
I am sure I am overlooking something simple but anyway here is the issue.
I am finally setting up my router with inductive homing switches (no limit switches) I have wired up the X axis and am trying to test it out. I am using Axis 2.8.1 for the interface and when I click on the Home Axis button (for the X) it homes as I expect in that it returns to the same location every time within about 0,01mm which is really good) what it doesn't do is set the position relative to the new home? (in my case it keep saying home is 56.501mm when it should be zero.
thanks
Luke
18 Apr 2021 17:57 #206317 by cmorley
Replied by cmorley on topic Homing setup
homing sets the machine origin, but then applies the current user cordinate system (usually g54).
Linuxcnc remembers the coordinate system offset from last time it was shut down.
To get linuxcnc to say zero then you need to zero out the coordinate system offset.
linuxcnc.org/docs/2.8/html/user/user-con...l#_when_you_are_lost
18 Apr 2021 18:38 #206319 by CaspianCmonster
Replied by CaspianCmonster on topic Homing setup
Thank you, I will give that a try.
Luke
Time to create page: 0.072 seconds
