TB6600 connections
30 Apr 2021 11:19 - 30 Apr 2021 11:27 #207439 by robertjenkins
TB6600 connections was created by robertjenkins
Hi
I have a Denford minimill but stupidly fried the driver board, so I decided to replace it with cheap TB6600 driver boards from Ebay, specifically ones like this
www.ebay.co.uk/itm/352981992806
I'm also using a generic Chinese BOB which always used to work.
I am using the same stepconf settings as before just to see if I can get any response from one axis
I am powering it with 24V. I am sending the STEP output to PUL+ and the DIR output to DIR+
Nothing on the ENA pins
When I run Test Axis, I measure a 3kHz square wave pulse going to PUL+ which looks about right
Step is going from 5V to 0V every few seconds
However, whether or not I have the stepper connected, all I get on all 4 A/B terminals is about 18V unchanging.
Something is not right but I don't have any idea what
Last edit: 30 Apr 2021 11:27 by robertjenkins.
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
30 Apr 2021 11:31 #207440 by BeagleBrainz
Replied by BeagleBrainz on topic TB6600 connections
300KHz ? According to the datasheet for the tb6600 chip max clk (step) frequency is 200kHz
Are you sure about that ?
Are your timing settings correct ?
30 Apr 2021 11:33 #207441 by robertjenkins
Replied by robertjenkins on topic TB6600 connections
Sorry that was a typo which I corrected, but not before you saw the original. It is about 3kHz
  • BeagleBrainz
  • Visitor
  • Visitor
30 Apr 2021 11:53 #207445 by BeagleBrainz
You have a quick schematic of your connections ?
30 Apr 2021 12:15 #207447 by robertjenkins
drive.google.com/file/d/1Re5qHdVmKsiJkiP...o_P/view?usp=sharing
This is just showing how I have the 12 pins of the module connected.
  • BeagleBrainz
  • Visitor
  • Visitor
30 Apr 2021 12:45 #207448 by BeagleBrainz
Yeah ok.
The DIR- & PUL- need to be connected to the GND of your BOB. As these are the cathodes of the LED of the opto coupler.
Do not connect the GND of the BOB to the 24v GND of the driver.
Usually it’s not a good idea to supply power to the stepper driver and not connect the stepper motors.
30 Apr 2021 13:46 #207455 by robertjenkins
Ok thanks - I'm confused about this
"Do not connect the GND of the BOB to the 24v GND of the driver."
They are the same, I think. I found the 24V by connecting one side of the multimeter to the GND of the BOB and probing various contacts with the other lead until I found 24V. Should I have looked for GND that isn't connected to the BOB?
I've also seen it suggested that I should put PUL+ and DIR+ to 5v+ and connect PUL- and DIR- to the BOB outputs (i.e. the other way round) - does that make sense?
  • Moderator
  • Moderator
30 Apr 2021 15:53 #207462 by tommylight
Replied by tommylight on topic TB6600 connections
Inputs have separate - inputs that can be connected to the BOB gnd. Drive power has another GND that should not be connected to input or BOB gnd.
That also works but might limit the step rate a bit in some cases.
30 Apr 2021 16:05 - 30 Apr 2021 16:05 #207464 by robertjenkins
Sorry, I'm still confused.
The AC output of the mains transformer goes to a (what is I presume a) rectifier unit which has a 24V DC output. The negative side of this is connected to the 0V of the BoB and all the other 0V terminals on the original drive board. So I don't see how I can avoid having the 0V of the BOB the same as the 0V of the 24V input.
If there was a -12V and +12V then I could see how this would be possible. But the wiring doesn't seem to arranged like this.
Last edit: 30 Apr 2021 16:05 by robertjenkins.
30 Apr 2021 16:12 #207465 by AgentWD40
Replied by AgentWD40 on topic TB6600 connections
For what it's worth I doubt they are actually using the tb6600 chip. From what I understand all these really cheap TB6600 drivers we can find on ebay, amazon, etc are actually running a slightly cheaper chip. I can't remember off the top of my head the chip number. I pulled the aluminum case off mine to check and it also wasn't a tb6600 as advertised. But I knew this going into it and still use them.
The following user(s) said Thank You: robertjenkins
