CNC Router - Dual Y's / Gantry
- Jeff_in_Wa
- Thank you received: 5
14 May 2021 00:13 #208771
by Jeff_in_Wa
CNC Router - Dual Y's / Gantry was created by Jeff_in_Wa
Today, I did a test job on the cnc router and thought I noticed the Gantry not synced in front to back moves. It was so subtle, I couldn't tell for sure.
I mapped out a my spoilboard for t-nuts and started the job
The first row seemed to be doing pretty well
The second row seemed to be slightly off
The third row was clearly showing a problem, as if progressive
The fourth row was wide towards Y1 and narrow towards Y2 as compared from the previous row
But what surprised me was that homing the machine showed Y2 hit the switch before Y1 did. But about a half inch
I have compared Y1 vs Y2 code in both the .hal and .ini settings, and can't find any discrepancies between the lines.
What I truly don't understand is that I can jog this machine all over the place, do a homing run and everything is perfect. I can do this over and over again, and I can't get the error showing up when running a job. The Y's hit the two switches at the back at exactly the same time after jogging.
So I know there is something different between jogging and executing gcode.
This made me think, that the Fusion 360 post may be the problem. I am letting the post write the machine code in the header.
Lastly, I have checked that the calibration on the machine is right. It is very right in all axis.
The only other thing I can think of at this point is I'm losing steps on one of the motors, presumably Y2. Or there is a gcode translation issue.
- Thank you received: 5321
14 May 2021 00:55 #208772
Replied by PCW on topic CNC Router - Dual Y's / Gantry
Progressive loss of position without a stall may be a timing issue
insufficient direction change setup and hold times or inverted
step polarity may cause loss of steps on reversals so may not show up
until hundreds of reversals.
- Jeff_in_Wa
14 May 2021 01:17 #208773
by Jeff_in_Wa
Replied by Jeff_in_Wa on topic CNC Router - Dual Y's / Gantry
Would you kindly lay out a plan of attack for me to fix this?
14 May 2021 01:34 #208775
If that is the problem increasing the direction setup and direction setup and direction hold timing should fix it.
There is no real disadvantage to large direction setup and hold times
so try 20000 for both
- Jeff_in_Wa
14 May 2021 04:17 #208780
by Jeff_in_Wa
I will do this and let the group know the outcome. Thanks a ton!
- Jeff_in_Wa
14 May 2021 19:32 #208844
by Jeff_in_Wa
Would you kindly look over my .hal file and see if there is something that sticks out at you?
In your suggestion above, you stated:
"If that is the problem increasing the direction setup and direction setup and direction hold timing should fix it."
You'll notice "direction setup" is stated twice. I don't know what to do here.
What I do know is that the:
setp stepgen.3.dirhold 38000
setp stepgen.3.dirsetup 38000 settings are already at 38000, when you suggested I raise mine to 20000
So clearly, something is amiss there
I have run the gantry across the limit switches so many times, I'm really not wanting to make any changes until you look the .hal file over... Please
# Generated by stepconf 1.1 at Sat May 1 10:56:44 2021
# overwritten when you run stepconf again
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS
loadrt hal_parport cfg="0 out"
setp parport.0.reset-time 5000
loadrt stepgen step_type=0,0,0,0
addf stepgen.update-freq servo-thread
#net spindle-cmd-rpm <= spindle.0.speed-out
#net spindle-cmd-rpm-abs <= spindle.0.speed-out-abs
#net spindle-cmd-rps <= spindle.0.speed-out-rps
#net spindle-cmd-rps-abs <= spindle.0.speed-out-rps-abs
#net spindle-at-speed => spindle.0.at-speed
net probe-in => motion.probe-input
net xstep => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
net xdir => parport.0.pin-03-out
net y1step => parport.0.pin-04-out
setp parport.0.pin-04-out-reset 1
net y1dir => parport.0.pin-05-out
net zstep => parport.0.pin-06-out
setp parport.0.pin-06-out-reset 1
net zdir => parport.0.pin-07-out
net y2step => parport.0.pin-08-out
setp parport.0.pin-08-out-reset 1
net y2dir => parport.0.pin-09-out
net xenable => parport.0.pin-14-out #Not sure what this is
net home-x <= parport.0.pin-10-in-not
net home-y1 <= parport.0.pin-11-in-not
net home-y2 <= parport.0.pin-12-in-not
net home-z <= parport.0.pin-13-in-not
net probe-in <= parport.0.pin-15-in
# X Axis
setp stepgen.0.position-scale [JOINT_0]SCALE
setp stepgen.0.steplen 50
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 38000
setp stepgen.0.dirsetup 38000
setp stepgen.0.maxaccel [JOINT_0]STEPGEN_MAXACCEL
net xpos-cmd joint.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => joint.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable joint.0.amp-enable-out => stepgen.0.enable
net home-x => joint.0.home-sw-in
# Y1 Axis
setp stepgen.1.position-scale [JOINT_1]SCALE
setp stepgen.1.steplen 50
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 38000
setp stepgen.1.dirsetup 38000
setp stepgen.1.maxaccel [JOINT_1]STEPGEN_MAXACCEL
net y1pos-cmd joint.1.motor-pos-cmd => stepgen.1.position-cmd
net y1pos-fb stepgen.1.position-fb => joint.1.motor-pos-fb
net y1step <= stepgen.1.step
net y1dir <= stepgen.1.dir
net y1enable joint.1.amp-enable-out => stepgen.1.enable
net home-y1 => joint.1.home-sw-in
# Y2 Axis
setp stepgen.2.position-scale [JOINT_2]SCALE
setp stepgen.2.steplen 50
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 38000
setp stepgen.2.dirsetup 38000
setp stepgen.2.maxaccel [JOINT_2]STEPGEN_MAXACCEL
net y2pos-cmd joint.2.motor-pos-cmd => stepgen.2.position-cmd
net y2pos-fb stepgen.2.position-fb => joint.2.motor-pos-fb
net y2step <= stepgen.2.step
net y2dir <= stepgen.2.dir
net y2enable joint.2.amp-enable-out => stepgen.2.enable
net home-y2 => joint.2.home-sw-in
# Z Axis
setp stepgen.3.position-scale [JOINT_3]SCALE
setp stepgen.3.steplen 50
setp stepgen.3.stepspace 0
setp stepgen.3.maxaccel [JOINT_3]STEPGEN_MAXACCEL
net zpos-cmd joint.3.motor-pos-cmd => stepgen.3.position-cmd
net zpos-fb stepgen.3.position-fb => joint.3.motor-pos-fb
net zstep <= stepgen.3.step
net zdir <= stepgen.3.dir
net zenable joint.3.amp-enable-out => stepgen.3.enable
net home-z => joint.3.home-sw-in
net estop-out => iocontrol.0.emc-enable-in
net tool-number <= iocontrol.0.tool-prep-number
net tool-change-loopback iocontrol.0.tool-change => iocontrol.0.tool-changed
Thank you so much!
# X Axis
# Y1 Axis
# Y2 Axis
# Z Axis
Thank you so much!
- Thank you received: 4144
14 May 2021 21:05 #208853
Replied by rodw on topic CNC Router - Dual Y's / Gantry
you need to share your ini file. Its all in there, not hal
14 May 2021 21:05 #208854
OK if the setup/hold times are already 38000 that's not likely the issue
Is the error only in one of the gantry joints?
Maybe mechanical or a drive/BOB issue
- Jeff_in_Wa
14 May 2021 21:19 #208856
by Jeff_in_Wa
At this point, the only thing I can see is that on home after a job is run, Y2 hits the home switch before Y1. So, I don't know which one is in error.
I have looked at my ball screw couplers to make sure they are tight. They seem to be fine. I was having stalling issues on the X gantry, and found that my velocity was too high. I lowered that down to 100 and the stalling stopped.
- Jeff_in_Wa
14 May 2021 21:24 #208857
by Jeff_in_Wa
Also, I can't find the problem in jogging. No matter how fast or hard I move the spindle around the x,y plane, homing returns the two Y's at the exact same time (hitting the switches)
It's when I'm running gcode
Time to create page: 0.109 seconds
