Lathe tailstock quill axis
  • NewGuyJim
  • NewGuyJim's Avatar Topic Author
  • New Member
  • New Member
20 May 2021 01:29 #209592 by NewGuyJim
Lathe tailstock quill axis was created by NewGuyJim
Hello! I follow very closely in @RotarySMP's footsteps getting here but I at long last have motors moving under control.
The question I have is, has anyone ever made the tailstock quill an axis? I'm a long way from needing to implement it, just curious. Being rather unimpressed with the flimsy tailstock that came with the 7x lathe I'm starting with, I have the opportunity to design something better from the start.
I don't know if the relevant people will see this, but thank you to all who had a hand in creating LinuxCNC; I look forward to exploring it in detail.
Jim
20 May 2021 10:22 #209634 by alkabal
Replied by alkabal on topic Lathe tailstock quill axis
Hi
Yes i have also moded my tailstock for add a motor and control this axe with Y letter, from my test impossible to use W due to some limitation in trajectory planner. (can't do rigid taping with W axis)
forum.linuxcnc.org/26-turning/38148-lath...-tailstock-as-w-axis
  • NewGuyJim
  • New Member
  • New Member
21 May 2021 01:19 #209713 by NewGuyJim
Replied by NewGuyJim on topic Lathe tailstock quill axis
Ok thank you for the reply!
Time to create page: 0.169 seconds
