RS485 Spindle controll
- icy
25 May 2021 19:44 - 25 May 2021 19:44 #210253
by icy
RS485 Spindle controll was created by icy
I am trying to get an working config for an 2.2kw chinaspindle with an RS485.
At the moment i am able to start/Stop and change direction of the spindle.
But only a an fix frequency of 100 HZ at my Omron MX2. I ve already tried to raise the spindle value in the settings of gmoccapy.
I am using an 7i767e with an Omron MX2 2.2kw , an USB 485 converter and an 2.2kw watercooled spindle from rattm. If i connect the Mx2 to the Hitachi software i can set the max frequency of 400.
Maybe someone take short look at my config files and have an hint or idea for me ?
Last edit: 25 May 2021 19:44 by icy.
- Thank you received: 4652
25 May 2021 21:42 #210267
Replied by andypugh on topic RS485 Spindle controll
I wouldn't expect a non-Hitachi VFD to work with the WJ200 driver.
It might be better to use the 7i76 spindle analogue control. It is more realtime, at least.
- icy
26 May 2021 08:37 #210320
by icy
Replied by icy on topic RS485 Spindle controll
The Omron Mx2 and the Hitachi Wj200 is identical in construction . There are some cnc system running the identical configurations without any problem,
26 May 2021 19:09 #210378
It looks like commanded-frequency needs to be in Hz, but you are passing it revs-per-second. However that isn't far off of being correct for a 2-pole motor, so probably isn't the problem.
I would initially suspect that the VFD config needs changing, so set min frequency, max frequency, pole count etc.
Time to create page: 0.065 seconds
