Need homing help please
27 May 2021 17:03 #210452 by kbec
Need homing help please was created by kbec
I am having issues homing my mill. It is a small Sherline mill and I have one limit switch on each axis, I am using a Mesa 7i96 card.
My limit switches are installed so they are triggered at -X, -Y and +Z.
When I try to home it now, for X, the table just travels to the right and since the switch never triggers I had to stop it manually.
The homing instructions page are a little advanced for me.
27 May 2021 17:18 #210454 by Clive S
Replied by Clive S on topic Need homing help please
Can you post the hal and ini files from the config folder
27 May 2021 17:26 #210455 by bevins
Replied by bevins on topic Need homing help please
Change the direction of homing by changing the sign of HOME_SEARCH_VEL.
27 May 2021 19:08 #210462 by kbec
Replied by kbec on topic Need homing help please
Here are my hal and ini files. In pncconf I have the inputs set as X Home, Y Home and Z home, and not set to limit, is that correct?
I did get the machine to go to the switch for Y, but it stopped when it hit it and did not back off.
27 May 2021 21:52 #210473 by Clive S
Re:
HOME_SEARCH_VEL = -1.000000 The sign determines which way it will search for the switch
HOME_LATCH_VEL = -0.500000 If you the omit the the sign it will back off the switch
HOME = 0.0 I would set this so that it moves a short distance away from the switch ie 2mm
HOME_FINAL_VEL = 0.000000 this setting is the speed it will move to the home position above if it is zero I don't think it will move
The following user(s) said Thank You: kbec
27 May 2021 23:09 #210477 by kbec
It may not be perfect, but at least I am able to get it to go to the switches and then back off a bit. Thanks a bunch
28 May 2021 00:55 #210484 by cmorley
Replied by cmorley on topic Need homing help please
I would make sure your axis directions are right first.
Time to create page: 0.098 seconds
