Mesa 7i94 + 7i78
- spi
- Thank you received: 8
01 Jun 2021 07:58 #210861
by spi
Mesa 7i94 + 7i78 was created by spi
I have a 7i94 working with a bunch of STMBL drives. Now I'd need to hook up the Jian-Ken spindle and I purchased a 7i78. My question is do I need to update the firmware on 7i94? In the download bundle for 7i94 there is no combo for 7i94+7i78.
A bonus question would be how can I mod the setup so that one of the step/dir outputs on the 7i78 would output PWM for a laser?
Thanks!
Seppo
Thanks!
Seppo
- Thank you received: 5326
01 Jun 2021 13:10 #210886
Replied by PCW on topic Mesa 7i94 + 7i78
- spi
30 Jun 2021 13:16 #213338
by spi
Replied by spi on topic Mesa 7i94 + 7i78
Thanks Peter!
I did:
sudo mesaflash --device 7i94 --write 7i94ss_7i78pd.bit --addr 10.10.10.10
The flashing seemed to work great. Now I'm a bit confused as to where the 7i78 pins are located in HAL Configuration. Do I need to tell LinuxCNC there's a 7i78 hooked up to the 7i94?
I can see Pins->hm2_7i94->gpio but they don't seem to be connected to the 7i78 pins when toggling the outputs in Test HAL Command.
I did:
30 Jun 2021 13:59 #213342
The expansion connector on the 7I94 needs to be enabled by setting GPIO41 low:
setp hm2_7i94.0.gpio.041.is_output true
setp hm2_7i94.0.gpio.041.out false
- spi
30 Jun 2021 19:40 #213358
by spi
Thanks! Is there some documentation I could read on how to get a daughter card set up? I wouldn't want to bug you with every detail...
01 Jul 2021 03:14 #213409
I would probably start with a pncconf configuration for a similar setup
(say a 7I92+G540) and then fix the FPGA card name. this will allow
you to setup the axis and axis calibration plus spindle PWM in the pncconf
GUI.
I did add the GPIO41 info to the 7I94 manual
GUI.
Time to create page: 0.212 seconds
