Homing direction..
- Pauchuk
01 Jul 2021 13:16 - 01 Jul 2021 13:17 #213431
by Pauchuk
Homing direction.. was created by Pauchuk
Hello. So, I am using 2 seperate switches on Y axis (2 steppers). My steppers home different directions. I put a minus sign on homing velocity on one of joints, it fixes direction, but, one switch has to be triggered once, another twice.. (for one its till it triggers switch, goes back a little, then again till triggers switch, another joint just triggers switch and stops). If there is no minus sign, they both trigger switch, goes away and then comes back trigger second time.
My files:
My files:
Last edit: 01 Jul 2021 13:17 by Pauchuk.
- Thank you received: 5326
01 Jul 2021 13:42 #213432
Replied by PCW on topic Homing direction..
You would have to reverse both the search and latch signs to have the same kind of homing cycle.
I think it would be better to change the direction pin polarity on one of the Y joints
and leave the homing identical, homing is already complicated enough...
- Pauchuk
01 Jul 2021 13:44 #213433
by Pauchuk
Replied by Pauchuk on topic Homing direction..
Just on drivers, for example?
01 Jul 2021 13:55 #213435
Probably the easiest is just to invert the parallel port pin that
drives the direction pin of the joint you need to reverse, something
like:
setp parport.0.pin-5-out-invert true
like:
- Pauchuk
06 Jul 2021 15:21 - 06 Jul 2021 15:23 #213863
by Pauchuk
Hi.. I have problem here. Homing works well till sometimes y axis want to home different directions, even after restarting linuxcnc or pc itself, wrong directions stay. How is that possible?
Last edit: 06 Jul 2021 15:23 by Pauchuk.
06 Jul 2021 15:48 - 06 Jul 2021 15:50 #213866
Sounds like the home switch is not working reliably
If its in the wrong state, LinuxCNC will try to back-off the switch.
Could also be direction wiring or electrical issue with direction signal
Last edit: 06 Jul 2021 15:50 by PCW.
- Thank you received: 7478
06 Jul 2021 17:05 #213874
Replied by tommylight on topic Homing direction..
Loose DIR wire ???Hi.. I have problem here. Homing works well till sometimes y axis want to home different directions, even after restarting linuxcnc or pc itself, wrong directions stay. How is that possible?
- Pauchuk
08 Jul 2021 11:18 - 08 Jul 2021 11:47 #214021
by Pauchuk
DId not want to make a new topic, so I will continue here
Got all switches working, squaring machine.
Now 2 things:
I use Mach3 BOB
1) When I home and select higher joggind speeds, I get error " joint 3 following error.." and sometimes " command (EMC_JOG_STOP) cannot be executed until machine is out of E stop and turned on.. Same speed works for X axis, when I choose to jog Z, it get me this error.. and increasing speed gives the same error.
2) I homed machine, then pressed to execute that G code " linuxcnc" and it crashed in to my limitswitch and crashed it (third one on this build)
Suggestions
Now 2 things:
I use Mach3 BOB
Suggestions
Last edit: 08 Jul 2021 11:47 by Pauchuk.
- Thank you received: 4654
09 Jul 2021 11:49 #214082
Replied by andypugh on topic Homing direction..
What does the command "uname -a" say?
It sounds like you might not be running realtime.
Time to create page: 0.834 seconds
