Tandem Y never runs two steppers
- hairyMug
- Thank you received: 3
I tried:
1. Using the the PnCConf tool, and specifying a "tandemY" axis BUT when I started LinuxCnc, it just showed 4 joints...
2. Using the the PnCConf tool, specified a "U" axis and then manually editing the INI to deleting the "U" spec and copy the "Y" axis... No dice...
3. Used the 7i96 Config tool, but still no dice...
In all cases, LinuxCnc just showed 4 joints and I could select a joint and move the axis but never did I get any config which showed just 3 joints for the X Y Z axis...
I did make sure the KINS entry was XZYY to correspond to the joints:
[TRAJ]COORDINATES = XZYY
[KINS]KINEMATICS = trivkins coordinates=XZYY kinstype=B
SO... all I need is to connect the two Y joints; Is it possible OR can I simply connect my two Y drivers to 1 stepper??
Thanks for clues!
Walt
- Thank you received: 5328
- Clive S
- Thank you received: 486
Do you have homing switches if so have you tried to home it. You should see 4 joints then when it is home it should just show 3 (axis)
Can you post the hal and ini files. In the ini file for the tandem axis you need to have
HOME_SEQUENCE = -2 The minus sign tells linux to sync the two motor
- hairyMug
This might be the missing link!
What section is that?
When I did a search for "sequence" in INI and HAL files, it did not find that word...
- Thank you received: 7481
If not, do not set a tandem axis, it will not work as it is intended to.
Again if not, set a 3 axis/3 joints machine just select the same axis outputs for two drives.
- hairyMug
>> just select the same axis outputs for two drives. <<
AFAIK, this did not work... Maybe after I find the HOME_SEQENCE setting as Clive mentioned...
I don't think any configuration utilities can set this up, but it should be pretty easy to add with some copy-pasting/number changing in the main hal file.
- hairyMug
So, I went back and created a whole new config (whith the 7i96 config tool) and put in -1 for the homing sequence and (of course), did not work ...
... it should not be this difficult to setup a simple 3 axis with two Y motors...
