Tandem Y never runs two steppers
- Thank you received: 5326
08 Jul 2021 03:49 - 08 Jul 2021 03:51 #214006
Replied by PCW on topic Tandem Y never runs two steppers
I think one issue is that there is no provision in the config utilities to setup
A gantry without gantry homing (squaring) ability. If you are comfortable with
hal you can add this to the hal file with some relatively simple copy-paste mods.
You could also do this rather simply in hardware if you don't need to jog the joints
separately, ether by simply tying the Y,Y2 drives STEP/DIR pins together, or if
the 7I96 doesn't provide enough electrical drive to run both drives, you could wire
the STEP+,DIR+,GND pins to step drive Y and STEP-,DIR-,+5V pins to step drive Y2
with the STEP- and DIR- pins of the Y step drive connected to GND and the STEP+
and DIR+ pins of the Y2 step drive connected to +5.
Last edit: 08 Jul 2021 03:51 by PCW.
- Clive S
- Thank you received: 486
08 Jul 2021 07:01 #214009
by Clive S
As have been said you need 2 inputs for the Y axis. Start by having just 1 home/limit switch for each side of the Y gantry (Y1 and Y2)
It is better to edit the hal and ini files directly. Show how you have actually wired the switches physically to the card.
Replied by Clive S on topic Tandem Y never runs two steppers
It's difficult because the crystal ball has broke . You need to give more info. for a start post your ini and hal files and answer the questions.... it should not be this difficult to setup a simple 3 axis with two Y motors...
- hairyMug
- Thank you received: 3
08 Jul 2021 09:43 #214017
by hairyMug
Replied by hairyMug on topic Tandem Y never runs two steppers
Thank you; I'll give one last shot through editing the HAL... and then try the hardware solution...
>> I just retired after 30+ years as IT guy and was hoping to get away from programming
but it looks like I may have to dive into the HAL manual...
- hairyMug
08 Jul 2021 15:33 #214032
by hairyMug
took the hardware approach and things are progressing...
next challenge; getting the right signals to the "spinx" board...
thanks for your help...
>> YOUR crystal ball must be working! :LOL
- fernandosf
- Thank you received: 17
17 Jul 2021 12:37 - 17 Jul 2021 12:39 #215134
by fernandosf
Hey TommyLight,
I have a gantry with 4 joints (XYYZ) and have set it up in the hope of been able to correct Y alignment by jogging both Y separately (although I still could not figure it out how). Is it possible?
Since I have just 1 input pin of parport to handle Limits+Homing I guess it is not possible to align Y by using 2 switches (one for Y1 and other for Y2). Is that correct?
Thanks,
Replied by fernandosf on topic Tandem Y never runs two steppers
Do you have limit switches on both sides?
If not, do not set a tandem axis, it will not work as it is intended to.
Again if not, set a 3 axis/3 joints machine just select the same axis outputs for two drives.
Hey TommyLight,
Thanks,
Last edit: 17 Jul 2021 12:39 by fernandosf. Reason: quoting for clarity
- Thank you received: 4149
17 Jul 2021 12:46 #215135
To align the gantry, yu just need to adjust the home_offset on each side.
Replied by rodw on topic Tandem Y never runs two steppers
Yes, thats how you do it but they must be separate inputs on your parport. Set the home_offset of both to = -1 and you should be good.
Thanks,
The following user(s) said Thank You: fernandosf
Time to create page: 0.251 seconds
