- Configuring LinuxCNC
- Basic Configuration
- Spindle Homing/Indexing w/external Index Pulse on non-1:1 spindle.
- CNC4Life
09 Jul 2021 18:36 - 09 Jul 2021 18:37 #214130
by CNC4Life
Spindle Homing/Indexing w/external Index Pulse on non-1:1 spindle. was created by CNC4Life
Ok guys/gals I’m getting oh so close to calling it good on my machine but I have one last issue.
The spindle motor on this machine is a Servo motor that is geared up to go from 5k to 7.5k. So the encoder feedback is coming from the motor w/index. But, it has a hal sensor on the spindle shaft. I’d like to use that as an index.
I have the hal sensor on one of the inputs on my 7i80 but it’s not the canned encoder index input as the motor has that taken. Also the sensor is 24v and the 7i33 doesn’t take accept 24v.
Last edit: 09 Jul 2021 18:37 by CNC4Life.
- Thank you received: 5329
09 Jul 2021 19:56 #214134
Replied by PCW on topic Spindle Homing/Indexing w/external Index Pulse on non-1:1 spindle.
Is the hal sensor a NPN or PNP (or push-pull) type?
- CNC4Life
11 Jul 2021 17:49 #214303
by CNC4Life
Replied by CNC4Life on topic Spindle Homing/Indexing w/external Index Pulse on non-1:1 spindle.
It's sourcing, if it was sinking I'd be golden.
- Thank you received: 2176
11 Jul 2021 20:04 #214316
Replied by Aciera on topic Spindle Homing/Indexing w/external Index Pulse on non-1:1 spindle.
I see two possible solutions:
1. Two resistors as a voltage divider and thus no isolation
2. Optocoupling module for electrical isolation
- CNC4Life
11 Jul 2021 20:56 #214321
by CNC4Life
Ok, I was wondering if there was a software option. But thank you.
