Using g-code values to control PWM
16 Aug 2021 14:51 #217890 by Krokrs
Using g-code values to control PWM was created by Krokrs
Hello,
 am trying to assign values from g-code (for example when i use M3 F1500) to control the value of PWM (pwmgen.0.value). Any idea what to add to the .hal script (or .ini ?) to make it work ?
Thx, Krokrs
16 Aug 2021 18:02 #217905 by chris@cnc
Replied by chris@cnc on topic Using g-code values to control PWM
One way could be to set a dummy axis like w.
If you write G0 W-5.00 and your PWM output is scaled to 10, PWM have 50% output power.
one expample of my used hal and ini.
# -----------PWM Generator signals/setup---
setp   hm2_7i76e.0.pwmgen.pwm_frequency 20000
setp   hm2_7i76e.0.pwmgen.00.output-type 1
setp   hm2_7i76e.0.pwmgen.00.scale  10
# -------------dummy axis control ------------------
net halui.program.is-running   => hm2_7i76e.0.pwmgen.00.enable
net w-enable    <= joint.6.amp-enable-out
net w-pos-cmd   <= joint.6.motor-pos-cmd
net w-pos-cmd   => joint.6.motor-pos-fb     hm2_7i76e.0.pwmgen.00.value
ini section
#************  dummy axis setup ******************************
[AXIS_W]
MAX_VELOCITY = 1000.0
MAX_ACCELERATION = 1000.0
MIN_LIMIT = -10.0
MAX_LIMIT = 0.5
[JOINT_6]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MIN_LIMIT = -10.0
MAX_LIMIT = 0.5
HOME_OFFSET = 0.0
HOME_SEQUENCE = 5
16 Aug 2021 23:53 #217933 by andypugh
Replied by andypugh on topic Using g-code values to control PWM
You can use spindle speed, as you suggest, then the HAL would need something like
net pwm-dc spindle.0.speed-out => pwmgen.0.value
Or you can use M67:
net pwm-dc motion.analog-out-00 => pwmgen.0.value
17 Aug 2021 13:40 #217982 by Krokrs
Replied by Krokrs on topic Using g-code values to control PWM
Hi, probably missunderstanding.
When I set M1 S1500, the spindle is not moving. Any of this M and S commands, which control the spindle aren´t doing anything.
So my solution is, that i connected PWM convertor and few other things and now am controlling speed of the spindle by the value of pwmgen.0.value.
And now the problem - i need the pwmgen.0.value to read the values from S-commmands. How to do it - i have no clue :D
Your solution is not working for me throughout in my view it´s because of my bad description of the problem.
17 Aug 2021 14:20 #217986 by andypugh
Do you want the pwmgen to control the spindle, or to control something else (like laser intensity?)
Can you attach your HAL file?
The following user(s) said Thank You: Krokrs
18 Aug 2021 07:04 #218043 by Krokrs
Solved !
It was just a basic thing - I didn´t watch properly the things & when i fixed one thing, it works. But thanks from help :)
Krokrs
Time to create page: 0.309 seconds
