- Configuring LinuxCNC
- Basic Configuration
- 2.8.2 Gantry configuration XYZY vs. XYYZ - is it supposed to matter?
- dokwine
- Thank you received: 11
# net jog.1.cont-plus vc-p4s.jog.1.plus => halui.axis.y.plus halui.joint.1.plus
# net jog.1.cont-minus vc-p4s.jog.1.minus => halui.axis.y.minus halui.joint.1.minus
# net jog.2.cont-plus vc-p4s.jog.2.plus => halui.axis.z.plus halui.joint.2.plus
# net jog.2.cont-mimus vc-p4s.jog.2.minus => halui.axis.z.minus halui.joint.2.minus
This led to a couple questions:
- Is there a point to connecting to both the halui axis pin and the halui joint pin for jogging? I understand jogging a single joint on a multi-joint axis for squaring, but then you wouldn't also be jogging the entire axis.
- In my case I'm set up in pncconf as XYYZ as the original order in which things were wired on the Mesa in 2.7. pncconf generated a correct-looking [KINS]
[KINS]
JOINTS = 4
KINEMATICS = trivkins coordinates=XYYZ kinstype=BOTH
and test jogging from axis seems to work fine.
the .hal lines above would have been a problem though as they assume joint 2 = axis z where on my machine joint 2 is the y axis slave. On a [KINS} XYZY configuration (like the sim gantry example) joint 2 would have remained the z axis and possibly have worked.
So. I realize this is 3rd-party hal code, but is it possible that elsewhere within LCNC there are assumptions favoring XYZY instead of XYYZ? I haven't found anything in the docs indicating a preference (which doesn't mean I didn't miss it
Ron
- Thank you received: 4149
The order in coordinates determines which joint belongs to which axis so it should be possible to freely move from XYYZ and XYZY etc by changing that value.I am doing a fresh install of the 2.8.2 iso on my 5i25/7i76 gantry machine with closed-loop steppers. Everything was running solid under 2.7.x for years and I'm working toward getting back to where I was with 2.7 on 2.8. when I went to setup my vistaCNC pendant I had some conflicts with these lines in the vendor's supplied .hal file:
[KINS]
JOINTS = 4
Thanks,
Ron
But the signals for home and limit switches created by stepconf and pncconf refer to X,Y,Z
Because I never used linuxcnc before we had joint axis, I think this is a carry over from the past. These signal names then become confusing if you do change like above because the second Y in this example will be named for the Z axis.
I would much prefer that these signals were named after the joints eg
joint-0-home not x-home etc
But I lost that argument years ago. To me, it makes the hal file much more readable.
- dokwine
In my case using XYYZ in pncconf resulted in the correct joints assigned to the correct axis. BUT, when I read down the pncconf-generated .hal under HALUI signals I have
- "net z-is-homed halui.joint.2.is-homed"
- "# AXIS Z JOINT 3 ... - with the correct setup for the z axis which is correct
- phillc54
- Thank you received: 2100
- "net joint-2-is-homed halui.joint.2.is-homed
- phillc54
I pushed a change to 2.8 and master that maps the correct joint.
If pncconf and stepconf referred to joints it would follow all the ini file format etc. Then all that is required is that the user entered the KINS data including a string for coordinates = XYZY, XYYX, YYXZ or whatever he wanted and pncconf should be able to support any kinematics and axis to joint mapping he wanted.
PNCCONF's restriction to trivial kinematics really stems back to not properly updating it for the move to independent joints/axes when I lost the argument.
- phillc54
I don't think that is the case, I think it is more that no-one has the time it would take to achieve, it would be a massive undertaking.PNCCONF's restriction to trivial kinematics really stems back to not properly updating it for the move to independent joints/axes when I lost the argument.
So was the joint axis work. It was released about 5 years ago.... I found it frustrating then that there were a number of bugs in the GUI's because the changes were not fully integrated but pncconf was not something I looked at then cos it did not support the 7i76e.
- phillc54
