Can not get jogging from Encoder after homing
- slammers
12 Sep 2021 18:05 #220347
by slammers
Can not get jogging from Encoder after homing was created by slammers
I am in the process of converting one of my mills from Mach3 to LinuxCNC. I am experimenting with a bench setup and a Mesa 7i93 thernet card. I ran the Pncconf wizard to get stared and have added hand wheel encoders for all axis. I choose the gmoccpy interface
I have manualy modified the HAL file to add
net x-jog-count => joint.0.jog-counts
net y-jog-count => joint.1.jog-counts
net z-jog-count => joint.2.jog-counts
I also set
set axis.x.jog-enable to true
set axix-x-jog-scale .0001
When I run the program and power the machine, turning the encoders move the axis as expected. But as sone as I home all axis, the encoders no longer function. Is this normal? The interface says the machie is in manual mode so I expected to be able to move the axis with the encoders.
My goal is to use the mill in manual mode with the encoders and have the encoders be disabled when in auto mode
Shawn
I also set
Shawn
- Thank you received: 2176
12 Sep 2021 18:41 #220350
Replied by Aciera on topic Can not get jogging from Encoder after homing
Note that since version 2.8 there is a separation between 'joints' and 'axis'. Roughly speaking 'joints' exist before homing and turn into 'axis' after homing. So to get jogging working after homing you want to change your hal to:
net x-jog-count => joint.0.jog-counts => axis.x.jog-counts
net y-jog-count => joint.1.jog-counts => axis.y.jog-counts
net z-jog-count => joint.2.jog-counts => axis.z.jog-counts
- slammers
13 Sep 2021 14:05 #220442
by slammers
Replied by slammers on topic Can not get jogging from Encoder after homing
Oh, thanks, I originally was using axis.z.jog-counts but it did not work at all. I will give this a try
Time to create page: 0.315 seconds
