Basic Gantry Machine Configuration
- Schaumstofffräsnewbie
28 Oct 2021 09:16 #224557
by Schaumstofffräsnewbie
Basic Gantry Machine Configuration was created by Schaumstofffräsnewbie
Hello everyone. After I finished my EtherCAT installation I want to bring things to work on my milling machine.
But i neither got stepper motors or a MesaCard, but servo-drives. Should I still use the Pncconf-Wizard for the first configuration, or should I code completely new .xml and .hal files by my own? If i have to take the second path, where should I start?
- Thank you received: 7478
01 Nov 2021 18:17 #224899
Replied by tommylight on topic Basic Gantry Machine Configuration
EtherCAT and Mesa Ethernet are not the same thing, so i do not get what are you asking.
For Mesa boards be it PCI/PCI-E/ETH use PncConf to make a config, you can make as many config as you like on the same PC, you can also make simulations of the configs, some already included, so you can test as much as you like with no hardware.
The following user(s) said Thank You: Schaumstofffräsnewbie
02 Nov 2021 07:11 #224958
Replied by Schaumstofffräsnewbie on topic Basic Gantry Machine Configuration
Thanks for the reply. I just basically wanted to know if I can use the Pncconf-Wizard, even if my setup does not contain a Mesa-card but uses servo drives instead of Steppers (so using the Stepper-Config Wizard does not seem to make sense for me).
Time to create page: 0.161 seconds
