GUI not loading but going to login
03 Nov 2021 15:19 - 03 Nov 2021 15:27 #225110 by Clive S
GUI not loading but going to login was created by Clive S
I have a PC that does not load the gui on start up, but instead goes to a login prompt.I have put the SSD in various PC's without any issues.  I suspect that the clue is in the first line of the pic.
Last edit: 03 Nov 2021 15:27 by Clive S.
03 Nov 2021 17:01 #225119 by bevins
Replied by bevins on topic GUI not loading but going to login
This has to do with microcode for the processor. Let me guess it is an AMD?
03 Nov 2021 18:41 #225132 by Clive S
Replied by Clive S on topic GUI not loading but going to login
Yes, You are correct it is a AMD Athlon 64 X2 3800+
04 Nov 2021 22:35 - 04 Nov 2021 22:36 #225287 by Clive S
Bump
I am not sure if this PC can be used
Last edit: 04 Nov 2021 22:36 by Clive S.
  • Moderator
  • Moderator
04 Nov 2021 23:47 #225301 by tommylight
Replied by tommylight on topic GUI not loading but going to login
Log in then type
startx
see what comes up, i have a suspicion on graphic something or another.
05 Nov 2021 09:45 #225379 by Clive S
Log in then type
startx
I have tried it with startx and sudo startx
  • Moderator
  • Moderator
05 Nov 2021 09:57 - 05 Nov 2021 09:59 #225380 by tommylight
Hmm that usually means another instance of xorg is already running, so type
sudo top
and check if there is anything X related already running.
Edit:
BTW, even if you manage to make it work, i would not use that PC for machine control, it seems like a hardware issue so sooner or later it will mess up.
Last edit: 05 Nov 2021 09:59 by tommylight. Reason: more info
05 Nov 2021 11:48 #225387 by Clive S
sudo top
Edit:
 The only command starting with x is xprtoid
Where will I find the logs as the X server is not starting
  • Moderator
  • Moderator
05 Nov 2021 13:33 #225395 by tommylight
sudo dmesg | grep xconf
sudo dmesg | grep video
sudo dmesg | grep vga
sudo dmesg | grep amd
sudo dmesg | grep radeon
sudo dmesg | grep nvidia
check each of them for clues.
Friendly advice:
From experience, if Linux does not start on a PC, do a clear cmos and try again, if it does not work = throw in a bin and get another one.
Linux works with all kinds of hardware and might have issues with some, but find me an operating system that works with RISC processors ???
05 Nov 2021 15:00 #225401 by Clive S
Friendly advice:
Tom . Thanks for the feedback, I hear you. I do have plenty of PC's
It's just like I don't like being beaten.
This pc will load linuxcnc through a terminal using $ linuxcnc machine-name.ini
I will check out the above.
Time to create page: 0.424 seconds
