- Configuring LinuxCNC
- Basic Configuration
- (Guidance desperately needed) HAL and .ini configuration for a Gantry Prototype
- Schaumstofffräsnewbie
04 Nov 2021 10:36 #225223
by Schaumstofffräsnewbie
(Guidance desperately needed) HAL and .ini configuration for a Gantry Prototype was created by Schaumstofffräsnewbie
Hello.
After the Installation of Linuxcnc and the succesful of the EtherCAT master and driver, I want to configure the HAL files and the .ini file for my gantry-based milling machine. For the start, I thought copying the example configuration for a gantry machine from linuxcnc into my /home/user/linuxcnc directory was the right step. But that is (sadly) already the point, where I am already in need of assistance.
But first some facts about the machine configuration:
Computer:
SERVO-DRIVES:
www.festo.com/net/de_de/SupportPortal/Do...-CiA402-20201111.zip , and I am currently searching the web if ther is an .xml for the I/O module (if needed)
After copying the gantry sample config, where should I start?
I can post more Information like .ini or.hal files if needed.
looking forward for your help guys,
Antonio
Computer:
- Siemens IPC227E as the controlling PC, also working as the EtherCAT Master
- [X-AXIS] FESTO CMMT-AS-C3-11A-P3-EC-S1; 2 times (the portal moves along the x-axis)
- [Y-AXIS] FESTO CMMT-AS-C2-11A-P3-EC-S1
- [Z-AXIS] FESTO CMMT-AS-C2-11A-P3-EC-S1
SERVO-DRIVES:
- [X-AXIS] FESTO EMMT-AS-80-MR-HS-RM; also 2 times
- [Y-AXIS] FESTO EMMT-AS-60-MR-HS-RM
- [Z-AXIS] FESTO EMMT-AS-60-SR-HS-RMB
- WEIDMUELLER UR20-FBC-EC 1334910000
Antonio
- Thank you received: 4149
04 Nov 2021 19:55 #225259
Replied by rodw on topic (Guidance desperately needed) HAL and .ini configuration for a Gantry Prototype
If you have movement on all motors (joints in Linuxcnc), your next step I think is to read the chapter in the docs titled homing configuration.
This deals with the ini file settings for joints and explains how to tie the two motors on the gantry together to act as one after they are homed.
Read it again and again until you understand it!
05 Nov 2021 06:02 #225360
Replied by Schaumstofffräsnewbie on topic (Guidance desperately needed) HAL and .ini configuration for a Gantry Prototype
I neither have movement on any joint, nor access to the I/O pins.
I dont even know if the Controller fully recognizes my Servo-Controllers.
I think I messed the configuration of the .ini and .hal files up, and do not really know where to start with troubleshooting.
Time to create page: 1.545 seconds
