- Thank you received: 59
Manually setup sserial HAL entry
- Michael
- Topic Author
4 years 11 months ago - 4 years 11 months ago #226582
by Michael
Manually setup sserial HAL entry was created by Michael
I have a 7i92 running a 7i77 and 7i78. The 7i77 has a 7i84 atached to the serial section. How do you manually setup the sserial_port_0=0000xx in HAL to recognize the 7i84?
Last edit: 4 years 11 months ago by Michael.
- Thank you received: 5334
4 years 11 months ago #226588
Replied by PCW on topic Manually setup sserial HAL entry
Its done in the config section of the hardware driver command line, for example:
loadrt hm2_eth board_ip="192.168.1.121" config=" num_encoders=6 num_pwmgens=6 num_stepgens=0 sserial_port_0=0012xxxx"
- Michael
- Topic Author
4 years 11 months ago #226590
by Michael
Replied by Michael on topic Manually setup sserial HAL entry
Yes I understand that but what do each of the entries mean for the ports? The 0=0012xxxx? Which do I change for the mode of 7i84
4 years 11 months ago #226591
The format of the sserisl setup string is described in the hostmot2 manual page
but is basically this:
Starting from the left, the numbers set the modes of sserial devices 0 through N
so "sserial_port_0=203xxx"
Would set
sserial channel 0 to mode 2
sserial channel 1 to mode 0
sserial channel 2 to mode 3
and disable sserial channels 3,4,5 (the "x" disables a channel if the channel exists)
If you have a 7I77 with a 7I84, its likely the 7I84 is sserial channel 2
The channel layout depends on the specific firmware used.
You can determine the channel layout by using mesaflash's --readhmid function
Would set
The following user(s) said Thank You: Michael
Time to create page: 0.103 seconds
