Linuxcnc + MESA 7i92h + pmdx126
09 Dec 2021 15:38 #228704 by sagreen
Linuxcnc + MESA 7i92h + pmdx126 was created by sagreen
I'm in the process of converting a mill that was running Mach 3 using a smooth stepper and a pmdx126 with a pmdx107 spindle controller.
What have I done so far:
1) Replaced ESS (smooth stepper) with a Mesa 7i92h
2) flashed firmware file 7i92_PMDX126x2D.bit to the 7i82h
3) Used PNCCONF to build a generic configuration, using discovery.
So far I have the X, Y and Z axis moving, still need to configure my Spindle, Probe and Home switches.
Does anyone have an example .hal & ini file that has a PMDX126 working?
I've configured the spindle for PWM on the only PWM in this firmware, but when I go into linuxcnc and try to run the spindle, nothing happens.
Thanks,
Scott...
09 Dec 2021 16:18 #228711 by tommylight
Replied by tommylight on topic Linuxcnc + MESA 7i92h + pmdx126
Here is everything regarding PMDX126 on this forum:
www.google.com/search?q=pmdx126+site%3Al...ABAA&sclient=gws-wiz
Time to create page: 0.342 seconds
