LinuxCNC on Raspberry, missing initool.hh
09 Mar 2022 07:54 #236741 by Guglielmi
Hello,
I installed LinuxCNC succesfully on Raspberry PI4 and now I'm playing a little bit configuring and customizing it.
I did some changes in the file "hal_gpio.c", the driver for GPIO control and I want to rebuild the software in order to apply my changes.
Well. in the directory "linuxcnc-dev/src" I call the command:
sudo make
and it works but after few seconds it stops with error:
"no rules to build object "../include/initool.hh", necessary for "headers".
What should I do to fix? Remove this file from a header? Create it.. but how? I'm not able to find the specific file on the web..
Bye
Andrea
09 Mar 2022 23:37 #236792 by andypugh
Replied by andypugh on topic LinuxCNC on Raspberry, missing initool.hh
initool.hh exists in 2.8 and not in Master.
Which version are you trying to build?
In Master it was removed as part of Dewey's tool table refactoring. (Which allows a database to be queried for tool data)
The following user(s) said Thank You: Guglielmi
10 Mar 2022 13:10 #236840 by Guglielmi
Replied by Guglielmi on topic LinuxCNC on Raspberry, missing initool.hh
At the end I tried to create a mock file just to understand if it was the only issue.. and I got another error in the line after
Finally, exaclty now.. I got the system built by myself following this video:
Install linuxcnc 2.8 on raspberry pi 3 B+ part3
Really cool because it is done step by step and at the contrary to some tutorial on a web page you can't face typing mistake,
sometime happens...
Now I checkout again version 2.8 and it works!
Thanks a lot and hopefully this post could help someone else.
Bye
Andrea
Time to create page: 0.159 seconds
