Configuring endstops in series - Error troubleshooting
13 Mar 2022 00:42 #237056 by MacLaddy
Hey folks,
I've been working my way through a new installation for an XYYZ PNC machine with a single parallel port. I have four inductive sensors for homing and endstops. One each for the X and Z axis, and one for each motor on the Y-Axis.
I'm not sure if these sensors are NO or NC. I have wired them in series where they remain at 24V until triggered, and then go to 0V. They are wired with X and Y1 together and Z & Y2. I have used Pin 10 for one set and 11 for the other.
Here's the issue. When I start LinuxCNC, I receive the following error. I'm not sure what it means. I've been able to work my way through several previous errors and the HAL/INI file, but this one has stumped me.
I appreciate any help offered. I just started with LinuxCNC, so please be gentle. I've also attached my HAL and INI file.
Afterthought: I realize many of the travel distances and velocities are out of whack (8 inches or so). I'll fix those once I can get the program to boot.
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
cory
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.2-11-g6a3d0a434
Machine configuration directory is '/home/cory/linuxcnc/configs/cutter'
Machine configuration file is 'cutter.ini'
INIFILE=/home/cory/linuxcnc/configs/cutter/cutter.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=XYYZ
KINEMATICS=trivkins coordinates=XYYZ
Starting LinuxCNC...
Found file(REL): ./cutter.hal
Found file(REL): ./custom.hal
Starting DISPLAY program: axis
emcMotionInit: emcJointInit(3) failed
waiting for s.joints<0>, s.kinematics_type<0>
config string '0 out'
Debug file information:
Note: Using POSIX realtime
INIFILE: ERR_CONVERSION, section=JOINT_3, tag=HOME_LATCH_VEL, num=1, lineNo=154
note: MAXV     max: 3.000 units/sec 180.000 units/min
note: LJOG     max: 3.000 units/sec 180.000 units/min
note: LJOG default: 0.300 units/sec 18.000 units/min
INIFILE: ERR_CONVERSION, section=JOINT_3, tag=HOME_LATCH_VEL, num=1, lineNo=154cory
Waiting for component 'inihal' to become ready...INIFILE: ERR_CONVERSION, section=JOINT_3, tag=HOME_LATCH_VEL, num=1, lineNo=154
..........INIFILE: ERR_CONVERSION, section=JOINT_3, tag=HOME_LATCH_VEL, num=1, lineNo=154
...........INIFILE: ERR_CONVERSION, section=JOINT_3, tag=HOME_LATCH_VEL, num=1, lineNo=154
..A configuration error is preventing LinuxCN
C from starting.
More information may be available when running from a terminal.
..1579
1606
.HAL: ERROR: exit called before init
<commandline>:0: waitpid failed milltask inihal
<commandline>:0: milltask exited without becoming ready
Stopping realtime threads
Unloading hal components
[/code]
File Name: cutter.hal
File Size:4 KB
File Name: cutter.ini
File Size:3 KB
13 Mar 2022 01:23 - 13 Mar 2022 01:23 #237058 by PCW
Just a a WAG but maybe the error:
emcMotionInit: emcJointInit(3)) failed
is because of the broken number in joint 3:
HOME_LATCH_VEL = 0.03 0000
Last edit: 13 Mar 2022 01:23 by PCW.
13 Mar 2022 01:40 #237064 by MacLaddy
It worked! Excellent WAG. I never would have noticed that white space, thank you. Now I just need to see if the homing sequence actually works.
13 Mar 2022 01:45 #237065 by tommylight
It is pinpointed exactly where the issue is, namely:
There can be no spaces there.
This reminds me, the second time i used LinuxCNC or EMC2 back then, wasted about an hour chasing why a new config is not starting, turned out a space in a config folder name was not allowed back then. :)
Just squash them one by one as they come.
P.S.
Almost forgot, welcome. :)
13 Mar 2022 01:46 #237066 by tommylight
What the heyyyyy...
Oh well, i was watching Nero3D on youtube while answering.
13 Mar 2022 03:56 - 13 Mar 2022 03:58 #237075 by MacLaddy
Thanks for the welcome. I have no doubt I'll be here a lot. Also never heard of Nero3D. Looks like a great channel. Appreciate the tip.
(I destroyed that quoted reply. Guess I need to also learn how to use this website)
Last edit: 13 Mar 2022 03:58 by MacLaddy.
13 Mar 2022 20:04 #237144 by MacLaddy
I provided incorrect information in the original post. Pins 10 and 11 remain at 0V until triggered, then go to 24V. I mention this because although LinuxCNC now boots for me, when I start the homing sequence it does not see it when I trigger the endstop. The z-motor just keeps spinning. I've tested the pin with a volt meter and I can see it goes high when I trigger it.
I have tried both :
net home-x-y1 <= parport.0.pin-10-in-not
net home-z-y2 <= parport.0.pin-11-in-not
and
Neither of these work. Is there another setting for this?
Thanks again.
File Name: cutter_2022-03-13.hal
File Size:4 KB
13 Mar 2022 21:19 #237147 by PCW
do
parport.0.pin-10-in
parport.0.pin-11-in
Change when you manually trip the switches?
If you are running Axis you can view these with halshow (Machine --> Show HAL configuration --> Watch )
13 Mar 2022 21:50 - 13 Mar 2022 21:51 #237149 by MacLaddy
do
parport.0.pin-10-in
parport.0.pin-11-in
I changed them back to pin-10-in. I don't understand what you mean by "change when you manually trip the switches?"  The motors are off the machine right now. I'm doing benchtop tests, so I start homing inside LCNC and manually trigger the Z-Stop since it is first in the sequence.
Thank you for the tip on viewing halshow. When doing this for PIN10, it shows parport.0.pin-10-in as red and parport.0.pin-10-in-not as yellow. They flip when triggered. PIN11 does the same. I'm pretty sure it is wired correctly, as either X or Y1 can trigger the change (but not at the same time). But it still doesn't register when homing.
Last edit: 13 Mar 2022 21:51 by MacLaddy.
13 Mar 2022 22:02 - 13 Mar 2022 22:04 #237150 by PCW
The shared home signal names don't match so there
is no connection from your hardware to LinuxCNC:
net home-x => joint.0.home-sw-in
net home-y1 => joint.1.home-sw-in
net home-y2 => joint.2.home-sw-in
net home-z => joint.3.home-sw-in
should be something like:
net home-x-y1 => joint.0.home-sw-in
net home-x-y1 => joint.1.home-sw-in
net home-z-y2 => joint.2.home-sw-in
net home-z-y2 => joint.3.home-sw-in
Last edit: 13 Mar 2022 22:04 by PCW.
Time to create page: 0.114 seconds
