Looks like the recommended solution is to add physical homing switches.
The Ursviken press brake I'm working on has one index near top of travel for both left and right ram. Then it has a prox sensor near the bottom of travel, only reachable if the tooling is removed, with limited documentation. It appears these might be for bottom limits to avoid over-extending the hydraulic cylinders.
If I were to try homing to only the index signal... has anyone done this successfully? I searched around a bit and did not find much hope.
I'm thinking of maybe trying to add a home-switch-out-pin to each of the two encoders in the Mesa firmware, on index this pin would always go high during positive counting/ negative during negative counting.
Just bringing this up in case anyone has a better solution. I could always add more sensors/switches. I'd like to complete this retrofit without adding additional sensors to the various axis.
