ANGULAR_UNITS = <units> - Specifies the machine units for rotational axes. Possible choices are deg, degree (360 per circle), rad, radian (2pi per circle), grad, or gon (400 per circle). This does not affect the angular units of NC code. In RS274NGC, A-, B- and C- words are always expressed in degrees.
I think this was a lot of my problem. 200 degrees per second is almost equal to 200 radians per minute.I am pretty sure that LinuxCNC doesn't use radians. It is possible that it _looks_ like radians through a combination of the axis step scale and the difference between deg/min and deg/sec
If you have the time, that would be great.
Code:I really ought to take what I learned today and take the time to audit these params for 2.9
