Servo motors control using LinuxCNC
25 Apr 2022 20:50 #241250 by Raouf Magdy
Servo motors control using LinuxCNC was created by Raouf Magdy
Hi folks, I have a stepper motor-based CNC and I would like to change the motors to servos, I need guidance for it, how can I configure the motors such as stepper motors what drives shall I use, and so on.
27 Apr 2022 23:48 #241419 by andypugh
Replied by andypugh on topic Servo motors control using LinuxCNC
We need more info. Especially about the drives. If the drives you use take step/dir then almost nothing will change.
If the drives take Modbis or EtherCAT then a lot will change. If the drives take analogue velocity commands then you will need new interface hardware.
The following user(s) said Thank You: Raouf Magdy
