Weird homing behavior. Y+Y2 out of sync
- AJ
- Topic Author
4 years 5 months ago #242056
by AJ
Weird homing behavior. Y+Y2 out of sync was created by AJ
Hello!
Long time lurker, first time poster here.
Finishing up my first DIY CNC plasma table. (Many of you guys have been a huge help to me without even knowing!
Big thanks for that!)
Got stuck with a weird homing issue - YY2 axis goes searching for the home sensors (both motors at the same time with the same velocity), latches to the sensors (also in sync), and then they both drive to the final home separately, Y and then Y2...
I've tried changing the homing sequence to 1 2 2 3, 1 -2 -2 3, 1 2 -2 3, 1 -2 2 3. Tried creating new configuration using pncconfig - always the same result.
After the homing everything works fine. Tried some dry runs, tried cutting some straight lines - no problem. Just the homing. Unless its supposed to be like that?
4 years 5 months ago #242070
Replied by rodw on topic Weird homing behavior. Y+Y2 out of sync
Try changing the home_sequence to -1 in you ini file. I don't think -2 is legal unless there is another joint axis.
The following user(s) said Thank You: AJ
4 years 5 months ago #242071
Replied by tommylight on topic Weird homing behavior. Y+Y2 out of sync
Does it have the same value for HOME_FINAL_VELOCITY ?
A video from each side of the gantry during homing would help, so that is 2 videos...
- Clive S
- Thank you received: 486
4 years 5 months ago #242075
by Clive S
Replied by Clive S on topic Weird homing behavior. Y+Y2 out of sync
In the ini file you have:-
HOME = 2950.0
HOME_OFFSET = 2960.000000 ( I generally use this to square the gantry with a low number like 1-5 mm)
HOME_SEARCH_VEL = 83.333333 ( this is the speed to the home switch)
HOME_LATCH_VEL = 16.666667 (this is the speed to the latch position. I generally back off so might need to put a - in front. ie -16.666)
HOME_FINAL_VEL = 0.000000 (this is the speed to the home position)
HOME_SEQUENCE = -2 ( this is fine for both Y joints)
From the manual linuxcnc.org/docs/devel/html/config/ini-...tml#_homing_sequence
HOME = 2950.0
4 years 5 months ago #242076
The initial HOME_SEQUENCE number may be 0, 1 (or -1). The absolute value of sequence numbers must increment by one — skipping sequence numbers is not supported. If a sequence number is omitted, HOME ALL homing will stop upon completion of the last valid sequence number.
Ref: linuxcnc.org/docs/devel/html/config/ini-...tml#_homing_sequence
That does not agree with the docs which state:HOME_SEQUENCE = -2 ( this is fine for both Y joints)
4 years 5 months ago #242078
So if he already has 0 for Z axis, 1 for X axis, yes, he should have -2 for Y tandem axis. Can not have 1 for X and -1 for Y, that will not work ... although i never checked, so ....
Not sure how you're reading this, but i am reading it as sequence numbers can be 0, 1 or -1, 2 or -2, 3 or -3, 4 or -4, 5 or -5 etc
- Clive S
4 years 5 months ago #242103
by Clive S
I don't see where he is skipping numbers
He has in the ini file :-
HOME_SEQUENCE Z = 0 . X = 1 . Y1 and Y2 = -2
- AJ
- Topic Author
4 years 5 months ago #242107
by AJ
Replied by AJ on topic Weird homing behavior. Y+Y2 out of sync
They do have the same HOME_FINAL_VELOCITY. In my understanding 0 = max velocity setting? And both joints were set to 25000mm/min if I remember correctly.
Here's a video Tommy
- AJ
- Topic Author
4 years 5 months ago #242108
by AJ
Rod, I've tried many different combinations for the homing sequence - always the same result...
4 years 5 months ago #242115
That looks perfectly normal.
The only possible issue might be miss wired switches, although i doubt it, so rake the gantry a bit on one side by hand and then home while watching from the side.
Otherwise, all is good, you have the final velocity set to maximum or 0 so after latching it flies to the final position, so a small difference during latching is magnified by the speed and the short distance it takes to get to final position.
Mine do that daily and i have some offset (5mm difference between them), but i have HOME_FINAL_VELOCITY at 30 so it goes slower and i enjoy watching them do their dance !
Time to create page: 0.072 seconds
