7i97 are encoder inputs limited to 5V
15 May 2022 18:03 #243033 by Rezonator
7i97 are encoder inputs limited to 5V was created by Rezonator
Hi, i am doing a retrofit of an old CNC table with mesa 7i97. And i already have installed encoders whose input is 10-30 VDC and output is push pull type. Can i connect that to my mesa 7i97 encoders inputs or does it have to be 5 V encoders. I did not find anything about that in manual but i want to be sure because there is 5V output voltage on encoder pins.
15 May 2022 18:26 #243034 by tommylight
Replied by tommylight on topic 7i97 are encoder inputs limited to 5V
5V only, as far as i know.
To use higher voltage ones, it needs to have voltage dividers for every signal pin used. It is very simple by using two resistors for each pin.
It would be nice to also add zener diodes to each input, just in case any of those resistors disconnects.
The following user(s) said Thank You: Rezonator
17 May 2022 12:04 #243138 by andypugh
Replied by andypugh on topic 7i97 are encoder inputs limited to 5V
The manual suggest that the inputs are safe to 12V:
www.mesanet.com/pdf/parallel/7i97man.pdf
Page 42.
But I would be tempted to divide-down to 5V anyway.
Time to create page: 0.071 seconds
