- Configuring LinuxCNC
- Basic Configuration
- Turn on linuxcnc for the first time and enable the abnormal action of the motor
- yi2580
- Thank you received: 3
25 May 2022 09:39 #243770
by yi2580
Turn on linuxcnc for the first time and enable the abnormal action of the motor was created by yi2580
Hello everyone, I encountered new problems when using. I closed the software linuxcnc and opened it again. When I enabled the motor again, the motor would move loudly. I felt like I had returned to the position when I closed the software and jogged the shaft last time. But if I don't close the software and turn on and off the enable, the motor won't move. Is there a problem where I haven't configured it? I don't know how to solve this problem. I hope someone can help me solve this problem. Thank you very much.
- Thank you received: 5325
25 May 2022 13:48 #243794
Replied by PCW on topic Turn on linuxcnc for the first time and enable the abnormal action of the motor
Sounds like an issue with the drives.
What kind of drives are they?
They may have an reset input input or mode that resets
the drive when enable is removed.
- yi2580
26 May 2022 01:00 #243863
by yi2580
Replied by yi2580 on topic Turn on linuxcnc for the first time and enable the abnormal action of the motor
Hello, thank you very much for your answer. In order to improve efficiency, I changed to ether cat driver. I asked the driver customer service. The customer service staff said that it might be a software problem. The driver said that there was no reset input. How can I cancel resetting the driver during startup? Thank you again for your reply
26 May 2022 02:56 #243867
OK It looks like you are not getting feedback position from the drive, this is likely
a hal setup error
a hal setup error
- yi2580
26 May 2022 03:36 #243869
by yi2580
First of all, thank you for your patient answer. It may be the Hal file setting error, but this problem will occur only when the software is restarted. This problem will not occur when the software is not restarted but only enabled. How can I modify Hal file correctly? Thank you for your guidance
26 May 2022 14:12 #243895
That is the expected result if linuxCNC is not getting the feedback position from your drive
and the drive position changes without LinuxCNC reading the new position.
I'm not sure what hal pin has the feedback position but this must come from the drive and be connected to the proper joint position feedback pin in your hal file.
- yi2580
27 May 2022 06:17 #243969
by yi2580
Hello, thank you. I think I have correctly configured the Hal file and drive, because only when I open the software to enable the motor for the first time, will the motor make abnormal noise and move. The subsequent enabling motors are very good. I don't know where I got it wrong.
- Thank you received: 7478
27 May 2022 10:55 #243979
Replied by tommylight on topic Turn on linuxcnc for the first time and enable the abnormal action of the motor
Check the DRO while the software is on but not enabled, if the numbers change, wire the enable signal properly to drives.
27 May 2022 15:14 #243995
its commanded position = feedback position when changing to the enabled state so there should be no
jump in the commanded position.
Still sounds like LinuxCNC is not getting the feedback position from the drive, because LinuxCNC should setHello, thank you. I think I have correctly configured the Hal file and drive, because only when I open the software to enable the motor for the first time, will the motor make abnormal noise and move. The subsequent enabling motors are very good. I don't know where I got it wrong.
- yi2580
30 May 2022 01:32 #244172
by yi2580
I checked the dro, but the number did not change. Each time I started, the dro value was the same as the last time I started itCheck the DRO while the software is on but not enabled, if the numbers change, wire the enable signal properly to drives.
Time to create page: 0.895 seconds
