Home in place (no switch) and machine cordinate offset.
4 years 5 months ago #244116
by Derek240
Home in place (no switch) and machine cordinate offset. was created by Derek240
Hi
Working on a knee mill conversion from UCCNC to LinuxCNC. The knee is the Z axis. When I home, the knee is all the way down at a visual mark and the machine coordinate is set to 14.00. I’m trying to get the same thing to happen with Linuxcnc but can’t seem to make it happen. These are the settings I’m using:
MIN_LIMIT = 0.00
MAX_LIMIT = 14.00
HOME = 14.00
HOME_OFFSET = 14.00
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = -0
HOME_IGNORE_LIMITS = YES
HOME_SEQUENCE = 0
I have tried a lot of combinations of home and home offset. Swapping 0 and 14. -14 etc etc and no matter what the Z machine coordinate is always 0.00 when I click the home button.
Any advice?
Thanks.
Derek
MIN_LIMIT = 0.00
MAX_LIMIT = 14.00
HOME = 14.00
HOME_OFFSET = 14.00
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = -0
HOME_SEQUENCE = 0
Any advice?
Thanks.
Derek
4 years 5 months ago #244118
by Clive S
if so:-
HOME_SEARCH_VEL = 0 this has to be a value
HOME_LATCH_VEL = -0 this has to be a value the -ve sign means it reverses
Replied by Clive S on topic Home in place (no switch) and machine cordinate offset.
Are you saying that the you don't get any movement ?Hi
MIN_LIMIT = 0.00
MAX_LIMIT = 14.00
HOME = 14.00
HOME_OFFSET = 14.00
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = -0
HOME_SEQUENCE = 0
Any advice?
Thanks.
Derek
if so:-
4 years 5 months ago #244125
by Derek240
Replied by Derek240 on topic Home in place (no switch) and machine cordinate offset.
Hi Clive
No it's a home in place setup with no switches or movement.
4 years 5 months ago #244316
Replied by andypugh on topic Home in place (no switch) and machine cordinate offset.
MAX_LIMIT = 0
MIN_LIMIT= -14
HOME = 0
HOME_SEARCH_VELOCITY = 0
Should do what you want.
MIN_LIMIT= -14
HOME = 0
4 years 5 months ago #244324
by Derek240
Hi Andy
I'm pretty sure that is what I'm doing now and yes it has the correct envelope but the machine coordinate with the knee down is 0.00 and I need it to be 14.00. I have a lot of code already with G53 G00 Z14.0 in it and I'd rather not have to edit all of it.
4 years 5 months ago - 4 years 5 months ago #244326
If you ever use Fusion360 that will put a G53 G0 Z0 at the start and end of each operation, that assumes that 0 is top.
If you want 14 at the top:
MAX_LIMIT = 14
MIN_LIMIT= 0
HOME = 14
<edit> Which is what you have. I don't think HOME_OFFSET matters with immediate homing but you could try setting that to zero.
MAX_LIMIT = 14
MIN_LIMIT= 0
HOME = 14
Last edit: 4 years 5 months ago by andypugh.
Time to create page: 0.093 seconds
