gantry mode issue
4 years 5 months ago - 4 years 5 months ago #244399 by Kasper-001
gantry mode issue was created by Kasper-001
is there a way to lock y1 y2 before homing , so they can´t move individual and damage the machine in jog mode before homing?
Last edit: 4 years 5 months ago by Kasper-001.
4 years 5 months ago #244405 by rodw
Replied by rodw on topic gantry mode issue
Short answer no, the system expects to be homed before jogging.
I've never had an issue with this requirement. I just power on and home all.
But this is Linuxcnc so anything is possible.
4 years 5 months ago #244407 by oldtech
Replied by oldtech on topic gantry mode issue
In Axis 2.8.2-11 the UI will generate an error if you try to move joint 1 or 2 before homing.
Cannot jog joint n because joint is synchronized.
To test, set the increment to the smallest and try jogging joint 1 or 2.
4 years 5 months ago #244409 by tommylight
Replied by tommylight on topic gantry mode issue
Exactly.
PncConf generated config will not allow jogging of tandem axis before homing.
4 years 4 months ago - 4 years 4 months ago #244469 by Kasper-001
Replied by Kasper-001 on topic gantry mode issue
i run gmoccapy 3.1.3.8,  maybe there is a way to code it, a way where jog is disable when not homed
i just made a config of gmoccapy from PncConf, and i can still move y1 y2 unhomed
Last edit: 4 years 4 months ago by Kasper-001.
4 years 4 months ago #244471 by oldtech
Perhaps there is a bug in 3.1.3.8.
I just tried it with gmoccapy in 2.8.2-11 and I still cannot jog y1 or y2 before homing.
Time to create page: 0.063 seconds
