gantry mode issue
  • Kasper-001
  • Kasper-001's Avatar Topic Author
  • Premium Member
  • Premium Member
01 Jun 2022 19:34 - 01 Jun 2022 19:41 #244399 by Kasper-001
gantry mode issue was created by Kasper-001
is there a way to lock y1 y2 before homing , so they can´t move individual and damage the machine in jog mode before homing?
Last edit: 01 Jun 2022 19:41 by Kasper-001.
01 Jun 2022 21:07 #244405 by rodw
Replied by rodw on topic gantry mode issue
Short answer no, the system expects to be homed before jogging.
I've never had an issue with this requirement. I just power on and home all.
But this is Linuxcnc so anything is possible.
01 Jun 2022 21:13 #244407 by oldtech
Replied by oldtech on topic gantry mode issue
In Axis 2.8.2-11 the UI will generate an error if you try to move joint 1 or 2 before homing.
Cannot jog joint n because joint is synchronized.
To test, set the increment to the smallest and try jogging joint 1 or 2.
01 Jun 2022 21:25 #244409 by tommylight
Replied by tommylight on topic gantry mode issue
Exactly.
PncConf generated config will not allow jogging of tandem axis before homing.
  • Kasper-001
  • Premium Member
  • Premium Member
02 Jun 2022 18:40 - 02 Jun 2022 18:45 #244469 by Kasper-001
Replied by Kasper-001 on topic gantry mode issue
i run gmoccapy 3.1.3.8,  maybe there is a way to code it, a way where jog is disable when not homed
i just made a config of gmoccapy from PncConf, and i can still move y1 y2 unhomed
Last edit: 02 Jun 2022 18:45 by Kasper-001.
02 Jun 2022 20:55 #244471 by oldtech
Perhaps there is a bug in 3.1.3.8.
I just tried it with gmoccapy in 2.8.2-11 and I still cannot jog y1 or y2 before homing.
02 Jun 2022 21:46 #244472 by tommylight
How is the tandem axis set up?
does the machine have separate home switches for both tandem joints?
Upload the hal and ini file here, the new ones.
  • Kasper-001
  • Premium Member
  • Premium Member
03 Jun 2022 18:18 #244529 by Kasper-001
i have no sensors connect yet, maybe thats why  im waiting for them to arrive i my mailbox,
here is my hal and ini
03 Jun 2022 21:10 #244541 by tommylight
Tandem joint do not work without sensors, although "immediate homing" might work, i just never tried it.
linuxcnc.org/docs/html/config/ini-homing.html#_immediate_homing
09 Jun 2022 23:06 #244825 by andypugh
Replied by andypugh on topic gantry mode issue
Are you talking about keyboard jogging, MPG jogging or some other jogging?
Time to create page: 0.223 seconds
