Adding coolant control with Mesa 7i76
20 Jul 2022 20:03 #247871 by edougawa
Adding coolant control with Mesa 7i76 was created by edougawa
Hi everyone, I’m new to linuxcnc and currently working on a machine that is built by someone else. The machine runs on a Mesa 7i76 board and I’m trying to add coolant control to linuxcnc (basic ON and OFF will be good enough). Where should I edit in the configuration to add the function and define the pin for the coolant control signal? Thanks.
20 Jul 2022 22:21 #247886 by JT
Replied by JT on topic Adding coolant control with Mesa 7i76
How did you create the configuration?
JT
20 Jul 2022 23:54 - 20 Jul 2022 23:55 #247893 by edougawa
Replied by edougawa on topic Adding coolant control with Mesa 7i76
Quick answer is, I didn't.
The machine is built and configurated by someone else and passed onto me. There isn't many documentation left. This is my first experience on LinuxCNC and still trying to understand how everything works on it. It would be great if there is any insight for what I should look for in the configuration files.
Last edit: 20 Jul 2022 23:55 by edougawa.
21 Jul 2022 14:39 #247947 by JT
Attach the ini and hal files so we can look at them.
JT
21 Jul 2022 19:49 #247984 by andypugh
Replied by andypugh on topic Adding coolant control with Mesa 7i76
Its going to be a line in the HAL file something like:
net flood iocontrol.0.coolant-flood => hm2_5i25.0.7i76.0.0.output-11
The following user(s) said Thank You: edougawa
21 Jul 2022 22:53 - 21 Jul 2022 22:54 #247994 by edougawa
andypugh post=247984 userid=723
This works! Thanks!
Last edit: 21 Jul 2022 22:54 by edougawa.
Time to create page: 0.253 seconds
