7i96s vfd control
- Samuelx
- Thank you received: 4
02 Aug 2022 19:00 - 02 Aug 2022 19:01 #248860
by Samuelx
7i96s vfd control was created by Samuelx
I got mesa 7i96S card and trying to connect it to my vfd.
VFD has
+10V output pin that gives +10V (measured on multimeter)
VI pin (analog signal frequency reference input) 0-10v
DCM/COM pin (common terminal of digital and control singnals)
I hooked it up to my 7i96s card ANALOG SPINDLE INTERFACE
vdf +10v output to mesa pin 24 (Spindle +)
vdf VI pin to mesa pin 23 (Spindle out)
vdf com/dcm pin to mesa pin 22 (Spindle -)
Is this connection right?
Next I need to modify hal and ini files ?
My spindle is spinning 50hz/1370rpm
I found this on google
So do I need to add this to my ini file?
loadrt scale count=1
VFD has
addf scale.0 servo-thread
setp scale.0.gain 0.007299270073
net spindle-speed-scale spindle.0.speed-out => scale.0.in
net spindle-speed-DAC scale.0.out => <your DAC pin name>
Where can I find my pin names that I need to use when modifying hal/ini?
Last edit: 02 Aug 2022 19:01 by Samuelx.
- Thank you received: 4654
02 Aug 2022 22:48 #248878
With LinuxCNC loaded, open a terminal window and type:
You can either copy and paste the output to a text editor (it's shift-ctrl-c in the terminal for copy) or send it direct to a file with
You probably want to run
too.
Replied by andypugh on topic 7i96s vfd control
halcmd show pinYou can either copy and paste the output to a text editor (it's shift-ctrl-c in the terminal for copy) or send it direct to a file with
halcmd show pin > pins.txtYou probably want to run
halcmd show paramPlease Log in or Create an account to join the conversation.
- Thank you received: 5325
02 Aug 2022 23:21 - 02 Aug 2022 23:22 #248880
Replied by PCW on topic 7i96s vfd control
How this is connected depends on you current hal/ini files
can you post them here?
You likely don't need the scale component as the analog scaling
is typically done with the PWM generators scale parameter.
Last edit: 02 Aug 2022 23:22 by PCW. Reason: sp
- Samuelx
03 Aug 2022 14:40 - 03 Aug 2022 14:51 #248935
by Samuelx
Replied by Samuelx on topic 7i96s vfd control
# Generated by PNCconf at Wed Aug 3 17:23:08 2022
# Using LinuxCNC version: Master (2.9)
# overwritten when you run PNCconf again
loadrt [KINS]KINEMATICS
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10" config="num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=0xxxxx"
setp [HMOT](CARD0).watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.z,pid.s
addf [HMOT](CARD0).read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf [HMOT](CARD0).write servo-thread
setp [HMOT](CARD0).dpll.01.timer-us -50
setp [HMOT](CARD0).stepgen.timer-number 1
# external output signals
# --- SPINDLE-CW ---
net spindle-cw => [HMOT](CARD0).ssr.00.out-00
# external input signals
# --- MIN-HOME-X ---
net min-home-x <= [HMOT](CARD0).gpio.000.in
# --- MIN-HOME-Z ---
net min-home-z <= [HMOT](CARD0).gpio.001.in
# AXIS X JOINT 0
setp pid.x.Pgain [JOINT_0]P
setp pid.x.Igain [JOINT_0]I
setp pid.x.Dgain [JOINT_0]D
setp pid.x.bias [JOINT_0]BIAS
setp pid.x.FF0 [JOINT_0]FF0
setp pid.x.FF1 [JOINT_0]FF1
setp pid.x.FF2 [JOINT_0]FF2
setp pid.x.deadband [JOINT_0]DEADBAND
setp pid.x.maxoutput [JOINT_0]MAX_OUTPUT
setp pid.x.error-previous-target true
# This setting is to limit bogus stepgen
# velocity corrections caused by position
# feedback sample time jitter.
setp pid.x.maxerror 0.012700
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-pos-fb => pid.x.feedback
net x-output <= pid.x.output
# Step Gen signals/setup
setp [HMOT](CARD0).stepgen.00.dirsetup [JOINT_0]DIRSETUP
setp [HMOT](CARD0).stepgen.00.dirhold [JOINT_0]DIRHOLD
setp [HMOT](CARD0).stepgen.00.steplen [JOINT_0]STEPLEN
setp [HMOT](CARD0).stepgen.00.stepspace [JOINT_0]STEPSPACE
setp [HMOT](CARD0).stepgen.00.position-scale [JOINT_0]STEP_SCALE
setp [HMOT](CARD0).stepgen.00.step_type 0
setp [HMOT](CARD0).stepgen.00.control-type 1
setp [HMOT](CARD0).stepgen.00.maxaccel [JOINT_0]STEPGEN_MAXACCEL
setp [HMOT](CARD0).stepgen.00.maxvel [JOINT_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net x-pos-cmd <= joint.0.motor-pos-cmd
net x-vel-cmd <= joint.0.vel-cmd
net x-output => [HMOT](CARD0).stepgen.00.velocity-cmd
net x-pos-fb <= [HMOT](CARD0).stepgen.00.position-fb
net x-pos-fb => joint.0.motor-pos-fb
net x-enable <= joint.0.amp-enable-out
net x-enable => [HMOT](CARD0).stepgen.00.enable
# ---setup home / limit switch signals---
net min-home-x => joint.0.home-sw-in
net min-home-x => joint.0.neg-lim-sw-in
net x-pos-limit => joint.0.pos-lim-sw-in
# AXIS Z JOINT 1
setp pid.z.Pgain [JOINT_1]P
setp pid.z.Igain [JOINT_1]I
setp pid.z.Dgain [JOINT_1]D
setp pid.z.bias [JOINT_1]BIAS
setp pid.z.FF0 [JOINT_1]FF0
setp pid.z.FF1 [JOINT_1]FF1
setp pid.z.FF2 [JOINT_1]FF2
setp pid.z.deadband [JOINT_1]DEADBAND
setp pid.z.maxoutput [JOINT_1]MAX_OUTPUT
setp pid.z.error-previous-target true
setp pid.z.maxerror 0.012700
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-pos-fb => pid.z.feedback
net z-output <= pid.z.output
setp [HMOT](CARD0).stepgen.01.dirsetup [JOINT_1]DIRSETUP
setp [HMOT](CARD0).stepgen.01.dirhold [JOINT_1]DIRHOLD
setp [HMOT](CARD0).stepgen.01.steplen [JOINT_1]STEPLEN
setp [HMOT](CARD0).stepgen.01.stepspace [JOINT_1]STEPSPACE
setp [HMOT](CARD0).stepgen.01.position-scale [JOINT_1]STEP_SCALE
setp [HMOT](CARD0).stepgen.01.step_type 0
setp [HMOT](CARD0).stepgen.01.control-type 1
setp [HMOT](CARD0).stepgen.01.maxaccel [JOINT_1]STEPGEN_MAXACCEL
setp [HMOT](CARD0).stepgen.01.maxvel [JOINT_1]STEPGEN_MAXVEL
net z-pos-cmd <= joint.1.motor-pos-cmd
net z-vel-cmd <= joint.1.vel-cmd
net z-output => [HMOT](CARD0).stepgen.01.velocity-cmd
net z-pos-fb <= [HMOT](CARD0).stepgen.01.position-fb
net z-pos-fb => joint.1.motor-pos-fb
net z-enable <= joint.1.amp-enable-out
net z-enable => [HMOT](CARD0).stepgen.01.enable
net min-home-z => joint.1.home-sw-in
net min-home-z => joint.1.neg-lim-sw-in
net z-pos-limit => joint.1.pos-lim-sw-in
# SPINDLE
setp pid.s.Pgain [SPINDLE_0]P
setp pid.s.Igain [SPINDLE_0]I
setp pid.s.Dgain [SPINDLE_0]D
setp pid.s.bias [SPINDLE_0]BIAS
setp pid.s.FF0 [SPINDLE_0]FF0
setp pid.s.FF1 [SPINDLE_0]FF1
setp pid.s.FF2 [SPINDLE_0]FF2
setp pid.s.deadband [SPINDLE_0]DEADBAND
setp pid.s.maxoutput [SPINDLE_0]MAX_OUTPUT
setp pid.s.error-previous-target true
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
net spindle-vel-cmd-rps <= spindle.0.speed-out-rps
net spindle-vel-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net spindle-vel-cmd-rpm <= spindle.0.speed-out
net spindle-vel-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-enable <= spindle.0.on
net spindle-cw <= spindle.0.forward
net spindle-ccw <= spindle.0.reverse
net spindle-brake <= spindle.0.brake
net spindle-revs => spindle.0.revs
net spindle-vel-fb-rps => spindle.0.speed-in
net spindle-index-enable <=> spindle.0.index-enable
sets spindle-at-speed true
# connect miscellaneous signals
# ---HALUI signals---
net axis-select-x halui.axis.x.select
net jog-x-pos halui.axis.x.plus
net jog-x-neg halui.axis.x.minus
net jog-x-analog halui.axis.x.analog
net x-is-homed halui.joint.0.is-homed
net axis-select-z halui.axis.z.select
net jog-z-pos halui.axis.z.plus
net jog-z-neg halui.axis.z.minus
net jog-z-analog halui.axis.z.analog
net z-is-homed halui.joint.1.is-homed
net jog-selected-pos halui.axis.selected.plus
net jog-selected-neg halui.axis.selected.minus
net spindle-manual-cw halui.spindle.0.forward
net spindle-manual-ccw halui.spindle.0.reverse
net spindle-manual-stop halui.spindle.0.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.axis.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
net estop-out => iocontrol.0.emc-enable-in
# ---manual tool change signals---
net tool-change-request <= iocontrol.0.tool-change
net tool-change-confirmed => iocontrol.0.tool-changed
net tool-number <= iocontrol.0.tool-prep-number
# ---ignore tool prepare requests---
[EMC]
MACHINE = Emco_PC_50_Turn
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = gmoccapy
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 2.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/samuel/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
LATHE = 1
DEFAULT_LINEAR_VELOCITY = 6.000000
MAX_LINEAR_VELOCITY = 25.000000
MIN_LINEAR_VELOCITY = 0.500000
DEFAULT_ANGULAR_VELOCITY = 12.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
EDITOR = gedit
GEOMETRY = xyz
CYCLE_TIME = 100
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
SERVO_PERIOD = 1000000
[HMOT]
CARD0=hm2_7i96.0
[HAL]
HALUI = halui
HALFILE = Emco_PC_50_Turn.hal
HALFILE = custom.hal
POSTGUI_HALFILE = gmoccapy_postgui.hal
POSTGUI_HALFILE = custom_postgui.hal
SHUTDOWN = shutdown.hal
[HALUI]
[KINS]
JOINTS = 2
KINEMATICS = trivkins coordinates=XZ
[TRAJ]
COORDINATES = XZ
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 1.25
MAX_LINEAR_VELOCITY = 12.50
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_X]
MAX_VELOCITY = 12.5
MAX_ACCELERATION = 750.0
MIN_LIMIT = -46.01
MAX_LIMIT = -0.99
[JOINT_0]
TYPE = LINEAR
HOME = -1.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 12.5
STEPGEN_MAXVEL = 15.62
STEPGEN_MAXACCEL = 937.50
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
# these are in nanoseconds
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
STEP_SCALE = 8000.0
MIN_LIMIT = -46.01
MAX_LIMIT = -0.99
HOME_OFFSET = 0.000000
HOME_SEARCH_VEL = 8.333333
HOME_LATCH_VEL = 0.500000
HOME_FINAL_VEL = 0.000000
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS = YES
HOME_SEQUENCE = 1
[AXIS_Z]
MAX_VELOCITY = 12.5
MIN_LIMIT = -0.01
MAX_LIMIT = 236.01
[JOINT_1]
TYPE = LINEAR
HOME = 41.5
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 12.5
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 20000
DIRHOLD = 20000
STEPLEN = 5000
STEPSPACE = 5000
STEP_SCALE = 8000.0
MIN_LIMIT = -0.01
MAX_LIMIT = 236.01
HOME_SEARCH_VEL = -8.333333
HOME_LATCH_VEL = -0.500000
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
[SPINDLE_0]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 2000.0
Last edit: 03 Aug 2022 14:51 by Samuelx.
- Samuelx
03 Aug 2022 16:09 #248946
by Samuelx
I also tryed to use mecact tool.
Tool is working but when trying to start linuxcnc i got folowing error.
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.0~pre0
Machine configuration directory is '/home/samuel/linuxcnc/configs/emco_pc_turn_50_mesact'
Machine configuration file is 'emco_pc_turn_50_mesact.ini'
INIFILE=/home/samuel/linuxcnc/configs/emco_pc_turn_50_mesact/emco_pc_turn_50_mesact.ini
VERSION=1.1
PARAMETER_FILE=emco_pc_turn_50_mesact.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
COORDINATES=XZ
KINEMATICS=trivkins coordinates=XZ
Starting LinuxCNC...
Starting LinuxCNC IO program: iov2
Found file(REL): ./emco_pc_turn_50_mesact.hal
iov2: exiting
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:16:80:86
hm2_eth: Unrecognized ethernet board found: 7I96S -- port names will be wrong
hm2_eth: discovered 7I96S
hm2/hm2_7i96.0: Low Level init 0.15
hm2/hm2_7i96.0: Smart Serial Firmware Version 43
hm2/hm2_7i96.0: 51 I/O Pins used:
hm2/hm2_7i96.0: IO Pin 000 (??-01): InM Input Module #0, pin in0 (Input)
hm2/hm2_7i96.0: IO Pin 001 (??-14): InM Input Module #0, pin in1 (Input)
hm2/hm2_7i96.0: IO Pin 002 (??-02): InM Input Module #0, pin in2 (Input)
hm2/hm2_7i96.0: IO Pin 003 (??-15): InM Input Module #0, pin in3 (Input)
hm2/hm2_7i96.0: IO Pin 004 (??-03): InM Input Module #0, pin in4 (Input)
hm2/hm2_7i96.0: IO Pin 005 (??-16): InM Input Module #0, pin in5 (Input)
hm2/hm2_7i96.0: IO Pin 006 (??-04): InM Input Module #0, pin in6 (Input)
hm2/hm2_7i96.0: IO Pin 007 (??-17): InM Input Module #0, pin in7 (Input)
hm2/hm2_7i96.0: IO Pin 008 (??-05): InM Input Module #0, pin in8 (Input)
hm2/hm2_7i96.0: IO Pin 009 (??-06): InM Input Module #0, pin in9 (Input)
hm2/hm2_7i96.0: IO Pin 010 (??-07): InM Input Module #0, pin in10 (Input)
hm2/hm2_7i96.0: IO Pin 011 (??-08): SSR #0, pin Out-00 (Output)
hm2/hm2_7i96.0: IO Pin 012 (??-09): SSR #0, pin Out-01 (Output)
hm2/hm2_7i96.0: IO Pin 013 (??-10): SSR #0, pin Out-02 (Output)
hm2/hm2_7i96.0: IO Pin 014 (??-11): SSR #0, pin Out-03 (Output)
hm2/hm2_7i96.0: IO Pin 015 (??-12): OutM Output Module #0, pin Out-04 (Output)
hm2/hm2_7i96.0: IO Pin 016 (??-13): OutM Output Module #0, pin Out-05 (Output)
hm2/hm2_7i96.0: IO Pin 017 (??-01): StepGen #0, pin Step (Output)
hm2/hm2_7i96.0: IO Pin 018 (??-14): StepGen #0, pin Direction (Output)
hm2/hm2_7i96.0: IO Pin 019 (??-02): StepGen #1, pin Step (Output)
hm2/hm2_7i96.0: IO Pin 020 (??-15): StepGen #1, pin Direction (Output)
hm2/hm2_7i96.0: IO Pin 021 (??-03): StepGen #2, pin Step (Output)
hm2/hm2_7i96.0: IO Pin 022 (??-16): StepGen #2, pin Direction (Output)
hm2/hm2_7i96.0: IO Pin 023 (??-04): StepGen #3, pin Step (Output)
hm2/hm2_7i96.0: IO Pin 024 (??-17): StepGen #3, pin Direction (Output)
hm2/hm2_7i96.0: IO Pin 025 (??-05): StepGen #4, pin Step (Output)
hm2/hm2_7i96.0: IO Pin 026 (??-06): StepGen #4, pin Direction (Output)
hm2/hm2_7i96.0: IO Pin 027 (??-07): Encoder #0, pin A (Input)
hm2/hm2_7i96.0: IO Pin 028 (??-08): Encoder #0, pin B (Input)
hm2/hm2_7i96.0: IO Pin 029 (??-09): Encoder #0, pin Index (Input)
hm2/hm2_7i96.0: IO Pin 030 (??-10): IOPort
hm2/hm2_7i96.0: IO Pin 031 (??-11): IOPort
hm2/hm2_7i96.0: IO Pin 032 (??-12): IOPort
hm2/hm2_7i96.0: IO Pin 033 (??-13): SSR #0, pin AC Ref (internal) (Output)
hm2/hm2_7i96.0: IO Pin 034 (??-01): IOPort
hm2/hm2_7i96.0: IO Pin 035 (??-14): IOPort
hm2/hm2_7i96.0: IO Pin 036 (??-02): IOPort
hm2/hm2_7i96.0: IO Pin 037 (??-15): IOPort
hm2/hm2_7i96.0: IO Pin 038 (??-03): IOPort
hm2/hm2_7i96.0: IO Pin 039 (??-16): IOPort
hm2/hm2_7i96.0: IO Pin 040 (??-04): IOPort
hm2/hm2_7i96.0: IO Pin 041 (??-17): IOPort
hm2/hm2_7i96.0: IO Pin 042 (??-05): IOPort
hm2/hm2_7i96.0: IO Pin 043 (??-06): IOPort
hm2/hm2_7i96.0: IO Pin 044 (??-07): IOPort
hm2/hm2_7i96.0: IO Pin 045 (??-08): IOPort
hm2/hm2_7i96.0: IO Pin 046 (??-09): IOPort
hm2/hm2_7i96.0: IO Pin 047 (??-10): IOPort
hm2/hm2_7i96.0: IO Pin 048 (??-11): IOPort
hm2/hm2_7i96.0: IO Pin 049 (??-12): IOPort
hm2/hm2_7i96.0: IO Pin 050 (??-13): IOPort
hm2/hm2_7i96.0: registered
hm2_eth: in hm2_eth_reset
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
./emco_pc_turn_50_mesact.hal:18: parameter or pin 'hm2_7i96s.0.watchdog.timeout_ns' not found
7479
Stopping realtime threads
Unloading hal components
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
http://pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Wed Aug 3 07:02:48 PM EEST 2022
UTC Date: Wed Aug 3 04:02:48 PM UTC 2022
this program: /usr/bin/linuxcnc_info
uptime: 19:02:48 up 35 min, 1 user, load average: 0,56, 0,59, 0,67
lsb_release -sa: Linuxmint Linux Mint 21 21 vanessa
linuxcnc: /usr/bin/linuxcnc
pwd: /home/samuel/linuxcnc/configs/emco_pc_turn_50_mesact
USER: samuel
LOGNAME: samuel
HOME: /home/samuel
EDITOR:
VISUAL:
LANGUAGE: en_US
TERM: dumb
COLORTERM:
DISPLAY: :0
DESKTOP: mate
display size: 1920x1080 pixels (508x285 millimeters)
PATH: /usr/bin:/home/samuel/linuxcnc/configs/emco_pc_turn_50_mesact/bin:/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
uname items:
nodename -n: samuel-OptiPlex-755
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT_RT Debian 5.18.5-1 (2022-06-16)
machine -m: x86_64
processor -p: x86_64
platform -i: x86_64
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-5.18.0-2-rt-amd64 root=UUID=e11f68d1-151d-4191-b0d9-f85eba8fe23a ro quiet splash isolcpus=1
model name: Intel(R) Core(TM)2 Duo CPU E8600 @ 3.33GHz
cores: 1
cpu MHz: 3325.229
parport: 0000-0000 : parport0 0000-0000 : parport0
serial: 0000-0000 : serial 0000-0000 : serial
Versions:
gcc: gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0
python: Python 3.10.4
git: git version 2.34.1
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.9.0~pre0
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /usr/lib/linuxcnc/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
PYTHON: /usr/bin/python3
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
un linuxcnc <none> <none> (no description available)
un linuxcnc-doc <none> <none> (no description available)
un linuxcnc-doc-en <none> <none> (no description available)
un linuxcnc-sim <none> <none> (no description available)
ii linuxcnc-uspace 2.9.0~pre0+git20220402.2500863908-4 amd64 motion controller for CNC machines and robots
03 Aug 2022 16:29 - 03 Aug 2022 16:45 #248948
Looks like an old copy of LinuxCNC 2.9 (before 7I96S support was added ~April this year)
Last edit: 03 Aug 2022 16:45 by PCW.
- Samuelx
03 Aug 2022 18:35 - 03 Aug 2022 18:37 #248958
by Samuelx
Where can i find the newest version?
And the next question is how to update
I am sorry about all the questions, I promise that after a year, I will be helping beginers here also.
Last edit: 03 Aug 2022 18:37 by Samuelx.
03 Aug 2022 19:09 #248961
How did you install 2.9?
- Samuelx
03 Aug 2022 19:14 - 03 Aug 2022 19:16 #248962
by Samuelx
i used this guide
forum.linuxcnc.org/9-installing-linuxcnc...mint-21-beta?start=0
Last edit: 03 Aug 2022 19:16 by Samuelx.
03 Aug 2022 19:31 - 03 Aug 2022 19:33 #248963
Wow that's a bit unfortunate... the Debian deb is from April 6 and the 7I96S support was added April 7...
I suspect the easiest way to install it is to get the latest LinuxCNC buildbot deb
Last edit: 03 Aug 2022 19:33 by PCW.
Time to create page: 0.680 seconds
