rtapi_app: caught signal 8 - dumping core
- Bari
- Thank you received: 234
02 Sep 2022 00:52 - 02 Sep 2022 04:28 #250960
by Bari
rtapi_app: caught signal 8 - dumping core was created by Bari
Brand new setup using stepconf. if I spin the spindle encoder quickly by hand I get: rtapi_app: caught signal 8 - dumping core
Even if the machine is still in e-stop. Simple config using stepconf LINUXCNC - 2.9.0~pre0
All default settings other than manual edit of LPT base address and changed setp encoder.0.position-scale 4000.000000 Default is like 100 vs 4000
Any ideas what causes this error?
The only mention of a similar error: forum.linuxcnc.org/24-hal-components/358...hercat-lcec?start=10
Last edit: 02 Sep 2022 04:28 by Bari. Reason: added more files
- Bari
02 Sep 2022 04:26 #250974
by Bari
Replied by Bari on topic rtapi_app: caught signal 8 - dumping core
Someone tested on LCNC 2.8 and there is no error.
Time to create page: 0.201 seconds
