Tandem Axis doesn't work
- chili023
- Thank you received: 7
15 Sep 2022 15:05 #252002
by chili023
Tandem Axis doesn't work was created by chili023
I have my first tandem axis setup to configure.
I cannot get the servos to drive together.
Setup as followed
Y1 = Stepgen0 (Joint 1)
Y2 = Stepgen1 (Joint 2)
X = Stepgen2 (Joint 0)
Z = Stepgen3 (Joint 3)
Nether while homing nore while jogging the two servos move together.
I can individually jog joint 1 and 2 but not together. What am I missing? Cannot be much.
I actually feel stupid for asking.
Anyway here are my files
Setup as followed
- mgm
- Thank you received: 13
15 Sep 2022 15:13 #252003
by mgm
Replied by mgm on topic Tandem Axis doesn't work
You need for example:
HOME_SEQUENCE = 0 for Z
HOME_SEQUENCE = 1 for X
HOME_SEQUENCE = -2 for both Y
The minus is for the tandem joint !
The following user(s) said Thank You: chili023
- Clive S
- Thank you received: 486
15 Sep 2022 15:56 - 15 Sep 2022 15:57 #252008
by Clive S
Replied by Clive S on topic Tandem Axis doesn't work
You might also need to looks at the signsHOME_SEARCH_VEL = -1.000000 (if you remove the - sign it will search in the opposite direction)
HOME_LATCH_VEL = -0.500000 (as above this is to back off the home switch)
The above seems to me to be very slow commands for the search
Last edit: 15 Sep 2022 15:57 by Clive S.
- chili023
15 Sep 2022 20:21 #252043
by chili023
Replied by chili023 on topic Tandem Axis doesn't work
The minus singe solved it.
Thank you.
Thank you.
Time to create page: 0.080 seconds
