PWM Closed Loop Spindle Control
- Brian_S
26 Sep 2022 21:15 #252803
by Brian_S
PWM Closed Loop Spindle Control was created by Brian_S
I'm having trouble getting closed loop spindle control to work with LinuxCNC 2.8.4 on a RPi using the GPIO driver as an output.
I'm following along with this example: wiki.linuxcnc.org/cgi-bin/wiki.pl?Closed...pindle_Speed_Control and I cannot get any output from the PID.
Here's an openloop PWM that is working (though I haven't done any scaling for the non-linear response). It gives good PWM on the correct RPi GPIO pin:
Here's the relevant section from the HAL file for the PID control that gives no PWM output. I tried making the PID transparent even to start with using the FF0 setting, but I just can't get anything output. I'm sure I've screwed something silly up. Any ideas?
# In order to have spindle feedback we need to use the encoder functions
# See the Spindle Feedback section of the docs: https://linuxcnc.org/docs/html/examples/spindle.html
loadrt encoder num_chan=1
addf encoder.update-counters base-thread
addf encoder.capture-position servo-thread
loadrt pwmgen output_type=0
addf pwmgen.make-pulses base-thread
# Set the spindle's top speed in RPM
setp pwmgen.0.scale 2000
# Set the PWM base frequency in Hz. The filter in the hardware is optimised for 10Hz
setp pwmgen.0.pwm-freq 10
net spindle-speed-cmd spindle.0.speed-out => pwmgen.0.value
net spindle-on spindle.0.on => pwmgen.0.enable
net spindle-pwm pwmgen.0.pwm => hal_pi_gpio.pin-05-out
# The standard Denford Orac position disc has 48 pulses per revolution
setp encoder.0.position-scale 48
# This is not a quadrature encoder (with A and B signals) so we use just a simple counter mode
setp encoder.0.counter-mode true
# Connect the HAL encoder outputs to LinuxCNC
net spindle-position encoder.0.position => spindle.0.revs
net spindle-velocity encoder.0.velocity => spindle.0.speed-in
net spindle-index-enable encoder.0.index-enable => spindle.0.index-enable
# Hook the spindle encoder HAL to the physical pins
net spindle-phase-a encoder.0.phase-A <= hal_pi_gpio.pin-29-in
net spindle-phase-b encoder.0.phase-B
net spindle-index encoder.0.phase-Z <= hal_pi_gpio.pin-26-inHere's the relevant section from the HAL file for the PID control that gives no PWM output. I tried making the PID transparent even to start with using the FF0 setting, but I just can't get anything output. I'm sure I've screwed something silly up. Any ideas?
loadrt pid num_chan=1
addf pid.0.do-pid-calcs servo-thread
setp pid.0.FF0 1.0
setp pid.0.Pgain 0
setp pid.0.Igain 0
setp pid.0.Dgain 0
setp pid.0.maxoutput 2000
# Convert revolutions per second (RPS) to revolutions per minute (RPM) for the output
setp scale.0.gain 60
# TODO: See what this setting actually does
# setp pwmgen.0.dither-pwm true
net spindle-enable spindle.0.on pwmgen.0.enable pid.0.enable
net spindle-position encoder.0.position spindle.0.revs
net spindle-index-enable encoder.0.index-enable spindle.0.index-enable
net spindle-velocity encoder.0.velocity scale.0.in
net spindle-phase-a encoder.0.phase-A hal_pi_gpio.pin-29-in
net spindle-index encoder.0.phase-Z hal_pi_gpio.pin-26-in
net spindle-velocity-rpm pid.0.feedback spindle.0.speed-in scale.0.out
net pid_command pid.0.command spindle.0.speed-out sum2.0.in0
net pid_output pid.0.output sum2.0.in1
net pwmgen_value pwmgen.0.value sum2.0.out
net pwmgen_pwm pwmgen.0.pwm hal_pi_gpio.pin-05-outPlease Log in or Create an account to join the conversation.
- Thank you received: 5325
26 Sep 2022 21:41 #252804
Replied by PCW on topic PWM Closed Loop Spindle Control
Missing the sum2 addf maybe?
With pid enable true and pid max_output not limiting the output,
the pid comps output should = the command with FF0=0
- Brian_S
26 Sep 2022 21:51 #252805
by Brian_S
Replied by Brian_S on topic PWM Closed Loop Spindle Control
OMG, I'm such a dumbass!
Didn't have:
Thanks so much for the quick response and the info!
Didn't have:
addf sum2.0 servo-threadThanks so much for the quick response and the info!
Time to create page: 0.173 seconds
