How jitter affects the no of steps or speed of the stepper motor
4 years 1 month ago #253101 by arvidb
What's the exact error message? (Run linuxcnc from the terminal and copy and paste the error message(s) here.)
4 years 1 month ago #253113 by PCW
Large jitter amounts can cause following errors.
These following errors are velocity dependent.
This can typically be eliminated by adjusting the DPLL
timing.
Also if you get Ethernet timeouts you will get following
errors so depending on you host hardware, you may need to
increase the servo thread period.
There is a workaround for this also if you cannot completely eliminate
Ethernet timeouts
To check timing, run LinuxCNC for a while and then run
this command in a terminal:
halcmd show param *.tmax
These times are in CPU clocks (on x86 hosts)
4 years 1 month ago #253217 by vkhargwanshi
Thanks PCW. I will try these.. By the way I am using Raspberry pi.. so hopefully will get something better....
4 years 1 month ago #253218 by vkhargwanshi
I am getting following 2 errors
1) Unexpected realtime delay on task 0 with period 2000000
2) hm2/hm2_7i96s.0:stepgen.00.maxval is too big for current step timings and position-scale. clipping to max possible.
Time to create page: 0.162 seconds
