Spindle speed wacky
- jlm123
- Thank you received: 6
03 Oct 2022 15:23 #253353
by jlm123
Spindle speed wacky was created by jlm123
Hey all:
(LinuxCNC 2.8.4, Debian 10, Probe Basic, Mesa 7i76e card)
I just redid my LinuxCNC computer in order to switch to the Probe Basic interface. Almost everything is working as expected, except the spindle controls. As i move the spindle speed slider going forward, the speed is all over the place (i.e when the slider is at 10%, the speed is 400rpm, at 30% its at max speed, at 50% it's down to 1000rpm, etc)
Also I have no speed control in reverse. Note that the spindle control was working on the old box in the QTDragon interface.
Thanks.
Thanks.
- Thank you received: 5325
03 Oct 2022 15:47 #253355
Replied by PCW on topic Spindle speed wacky
Did you change the hal file?
- jlm123
03 Oct 2022 17:33 #253360
by jlm123
Replied by jlm123 on topic Spindle speed wacky
I copied the values over from the old hal and ini files.
03 Oct 2022 17:43 #253362
Can you post you current hal/ini files?
- jlm123
03 Oct 2022 17:47 #253363
by jlm123
Here you go.
Ini file:
Ini file:
03 Oct 2022 17:56 - 03 Oct 2022 17:56 #253364
I see at least one issue:
net spindle-vel-cmd-rpm => pid.s.command
should be
net spindle-vel-cmd-rpm-abs => pid.s.command
should be
Last edit: 03 Oct 2022 17:56 by PCW.
- jlm123
03 Oct 2022 19:06 #253368
by jlm123
Tried that. If fixed the reverse speed control, so now both forward and reverse have the wackiness with the slider.
Moving the slider down from 100%, the spindle slows as it approaches arounf 65%, then goes to full speed and repeats the process at around 35%.
03 Oct 2022 19:16 #253370
In addition to the -abs change, these items in the ini file should be changed
OUTPUT_SCALE = 5000
(was 100)
OUTPUT_MIN_LIMIT = 0
(was -5000)
OUTPUT_SCALE = 5000
(was 100)
(was -5000)
- jlm123
03 Oct 2022 19:31 #253372
by jlm123
Thanks PCW - that fixed the wackiness with the slider. However, the spindle is now truning at 300rpm at 100% (it should be running at 5000)
03 Oct 2022 20:07 #253377
I would check (with halshow)
hm2_7i76e.0.7i76.0.0.spinout-scalemax
And check (with a voltmeter)
The spindle 10V supply (TB4 pin 3)
and output voltage (TB4 pin 2),
both relative to TB4 pin1
