- Thank you received: 6
Spindle speed wacky
4 years 4 weeks ago #253368
by jlm123
Replied by jlm123 on topic Spindle speed wacky
Tried that. If fixed the reverse speed control, so now both forward and reverse have the wackiness with the slider.
Moving the slider down from 100%, the spindle slows as it approaches arounf 65%, then goes to full speed and repeats the process at around 35%.
4 years 4 weeks ago #253370
Replied by PCW on topic Spindle speed wacky
In addition to the -abs change, these items in the ini file should be changed
OUTPUT_SCALE = 5000
(was 100)
OUTPUT_MIN_LIMIT = 0
(was -5000)
OUTPUT_SCALE = 5000
(was 100)
(was -5000)
4 years 4 weeks ago #253372
by jlm123
Thanks PCW - that fixed the wackiness with the slider. However, the spindle is now truning at 300rpm at 100% (it should be running at 5000)
4 years 4 weeks ago #253377
I would check (with halshow)
hm2_7i76e.0.7i76.0.0.spinout-scalemax
And check (with a voltmeter)
The spindle 10V supply (TB4 pin 3)
and output voltage (TB4 pin 2),
both relative to TB4 pin1
4 years 4 weeks ago #253386
Replied by tommylight on topic Spindle speed wacky
Encoder issues...
What encoder?
How it is wired to Mesa?
Does it have a shielded and grounded wire?
Is it a differential or single ended encoder?
Is the Mesa set up for differential or single ended?
What encoder?
4 years 4 weeks ago #253395
by jlm123
The spindle.output is set at 300 as shown in the watchlist -so I have to look for it in the hal file it looks like.
Time to create page: 0.182 seconds
