Disable homing of an axis
- turbostew
- Thank you received: 8
08 Nov 2022 17:35 #256221
by turbostew
Disable homing of an axis was created by turbostew
Hey All,
I have a mill with a 4th (rotary) axis. I have no home switches on the 4th axis. What I want is to press "home all" and my 4th axis will do nothing but turn the DRO green (indicating it is homed). I want it to use the current position at startup as the "home position". Right now it zeros out the position (DRO) when "home all" is pressed.
I actually searched for about an hour and figured this topic was beat to death but I couldn't really find an answer, so I apologize in advance if I missed the obvious....
HOME_OFFSET = 0.0
HOME = 0.0
HOME_SEARCH_VEL = 0.0
HOME_LATCH_VEL = 0.0
HOME_FINAL_VEL = 0.000000
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS = YES
HOME_SEQUENCE = 0
HOME_IS_SHARED = 0
VOLATILE_HOME = 0
HOME_OFFSET = 0.0
HOME = 0.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
HOME_IS_SHARED = 0
VOLATILE_HOME = 0
08 Nov 2022 18:01 #256227
Replied by andypugh on topic Disable homing of an axis
That ought to work, but maybe try HOME_SEQUENCE = 1
- turbostew
08 Nov 2022 19:13 #256234
by turbostew
Replied by turbostew on topic Disable homing of an axis
I posted my ini file that currently does NOT work....
08 Nov 2022 19:59 #256236
Yes, I understand that. And I think it should have worked.
In that I was saying that the problem isn't obvious to me.
- HansU
- Thank you received: 217
08 Nov 2022 20:19 #256239
by HansU
Replied by HansU on topic Disable homing of an axis
You could do this with a little macro or a python snippet or so.
Basically
1. save the current positionWhere #<_a> is a predefined parameter (see linuxcnc.org/docs/html/gcode/overview.ht...ned-named-parameters)
2. do homing
3. modify the offset to restore the old position, here using G54 (^=P1)
Basically
#<a_pos> = #<_a>2. do homing
G10 L20 P1 A#<a_pos>Please Log in or Create an account to join the conversation.
- turbostew
08 Nov 2022 20:57 - 14 Nov 2022 22:29 #256243
by turbostew
Thanks All,
I think i have a solution. I seem to be able to do this using HOME_ABSOLUTE_ENCODER = 2 even though I am not using abs encoders....
Last edit: 14 Nov 2022 22:29 by turbostew.
The following user(s) said Thank You: HansU, sf9090
