MPG setup for lathe
- 109jb
- Thank you received: 15
08 Dec 2022 21:10 #258912
by 109jb
MPG setup for lathe was created by 109jb
Not sure if I'm posting in the right place, but I'm starting planning for setting up my lathe for CNC. My goal is to have a lathe that can be operated in program mode like any other CNC lathe, but also operate in a pseudo manual mode from the jog screen. For this I am thinking of 3 MPG wheels. The first 2 would control X and Z. No magic here and done plenty of times that I have found. The difference is that I would like the 3rd MPG to perform coordinated motion of the X and Z to simulate a manual lathe compound slide. What I envision is setting the "compound angle" in the GUI and then when you turn that MGP in jog mode that it would move the X and Z in coordinated motion to achieve the angle desired. How would one go about setting this up?
- JPL
- Thank you received: 118
08 Dec 2022 23:08 #258928
by JPL
Replied by JPL on topic MPG setup for lathe
There's a recent (ongoing) discussion about this right here: forum.linuxcnc.org/38-general-linuxcnc-q...e-lathe-mode?start=0
So, yes, it is possible using the work made by dgarrett.
- JPL
08 Dec 2022 23:24 #258931
by JPL
Just saw that the there's already a commit for this. The component can be found here: github.com/LinuxCNC/linuxcnc/blob/master...onents/anglejog.comp
Sim config (axis) is here: github.com/LinuxCNC/linuxcnc/tree/master...gs/sim/axis/anglejog
- 109jb
09 Dec 2022 01:55 #258957
by 109jb
Replied by 109jb on topic MPG setup for lathe
That's great!!! Thank you. I will give it a try in SIM mode shortly.
Time to create page: 0.154 seconds
