Home inductive switches for Mesa 7i96s
- Markgonz
05 Jan 2023 18:14 - 05 Jan 2023 18:14 #261015
by Markgonz
Home inductive switches for Mesa 7i96s was created by Markgonz
Hello everyone,
Trying to understand home switches for a future mill build and decide what I should buy, I have a 7i96s, reading the descripition says the following:
11 isolated inputs provided for general control use including limit switch and control panel inputs. Inputs operate with 3V to 36V DC and can have a positive or negative common for sourcing or sinking input applications.
I guess then that it doesn't matter if I get PNP or NPN as long as I do the correct installation right?
Also after some research seems that NC (normally closed) is recommended for safety in case a cable breaks.
Thanks in advance!
Thanks in advance!
Last edit: 05 Jan 2023 18:14 by Markgonz.
- Thank you received: 7478
05 Jan 2023 19:41 #261025
Replied by tommylight on topic Home inductive switches for Mesa 7i96s
Yes.
Yes.
- Markgonz
05 Jan 2023 21:56 #261040
by Markgonz
Replied by Markgonz on topic Home inductive switches for Mesa 7i96s
Thanks!!
- Thank you received: 5325
05 Jan 2023 22:09 #261043
Replied by PCW on topic Home inductive switches for Mesa 7i96s
In general I would have a slight bias towards PNP sensors for a 7I96/7I96S
The reason is that with a PNP common connection (input common to ground)
You can mix input voltage levels (so if you needed to sense 5V signals,
say for a MPG, you could)
The following user(s) said Thank You: tommylight, SupplySergeant, Markgonz, al_sur_dionisis
Time to create page: 0.505 seconds
