- Configuring LinuxCNC
- Basic Configuration
- Dual Z issue with tandem Z: wiring seems fine, but no movement
- Doug @ Design8Studio.com
- Thank you received: 46
10 Jan 2023 01:58 #261403
by Doug @ Design8Studio.com
Dual Z issue with tandem Z: wiring seems fine, but no movement was created by Doug @ Design8Studio.com
Hello all! As you know I am really new to LinuxCNC. I'm running a LowRider v3 (mostly printed CNC) for plasma — QtPlasmaC.
I have wiring all testing OK, both from MESA 7i96s to the stepper drivers, and from the drivers to the steppers themselves.
All joints home except tandem Z.
If I swap the Z2 wiring onto the 7i96s sockets for Z1, then Z2 wiring works fine and the Z2 motor works great. If I swap Z1 (which works fine on the primary Z sockets) over to tandem Z sockets, Z1 stops working.
As is typical with LowRider, I have 5 steppers: X, Y1, Y2, Z1, Z2.
In my INI file, for homing, I have:
X:
[JOINT_0]
HOME_SEQUENCE = 1
Y1:
[JOINT_1]
HOME_SEQUENCE = -2
Y2:
[JOINT_2]
HOME_SEQUENCE = -2
Z1:
[JOINT_3]
HOME_SEQUENCE = -0
Z2:
[JOINT_4]
HOME_SEQUENCE = -0
Here are my INI and HAL files.
Any chance you all can spot something I'm missing?
Thanks again for being awesome.
X:
[JOINT_0]
HOME_SEQUENCE = 1
Y1:
[JOINT_1]
HOME_SEQUENCE = -2
Y2:
[JOINT_2]
HOME_SEQUENCE = -2
Z1:
[JOINT_3]
HOME_SEQUENCE = -0
Z2:
[JOINT_4]
HOME_SEQUENCE = -0
- Thank you received: 7478
10 Jan 2023 02:17 #261407
Replied by tommylight on topic Dual Z issue with tandem Z: wiring seems fine, but no movement
Just a stab in the dark, but try:
HOME_SEQUENCE = -1 for both Z
HOME_SEQUENCE = -3 for both Y
HOME_SEQUENCE = 2 for both X
If it complains about -3 value, try:
HOME_SEQUENCE = -2 for both Y
HOME_SEQUENCE = 3 for both X
The following user(s) said Thank You: Doug @ Design8Studio.com
10 Jan 2023 02:30 #261409
Replied by Doug @ Design8Studio.com on topic Dual Z issue with tandem Z: wiring seems fine, but no movement
Will give that a try! Thank you! Will report back.
10 Jan 2023 02:37 #261411
Your reply said "both X" but there is only one X stepper. I'm assuming that won't matter.
10 Jan 2023 02:49 #261413
Sorry, copy/paste enthusiasm !
10 Jan 2023 03:15 #261415
Hey, that was the ticket! The first suggestion you made did the trick! You are the man! Thank you!
- Thank you received: 4149
10 Jan 2023 05:12 #261419
Replied by rodw on topic Dual Z issue with tandem Z: wiring seems fine, but no movement
I thought the first non-negative joint needed to be a 0, then sequential. eg X = 0, Y=Y2 = -1, Z=Z2= -2
Just play with the order to see if you can home Z first in case it collides with something
10 Jan 2023 05:22 #261421
Thanks! I'm reading up now on this at:
linuxcnc.org/docs/html/config/ini-homing.html#_home_sequence
I will get my head around it so I get the machine axes homing in the right order of priority!
10 Jan 2023 05:26 #261422
I'm not sure if you will be able to get the Z to home before the X given the behaviour I see on my gantry machine becasue of the multiple joint axes.
10 Jan 2023 05:29 #261423
The LowRider v3 is made to do Z homing to Z max, and I am setup for that. My unstudied knee-jerk thought is that Z should be homed upwards first, which should make sure that X and Y movements with the plasma torch will be well above anything laying on the table. Does this sound right to you?
