- Configuring LinuxCNC
- Basic Configuration
- Dual Z issue with tandem Z: wiring seems fine, but no movement
- Thank you received: 4149
10 Jan 2023 05:36 #261425
Replied by rodw on topic Dual Z issue with tandem Z: wiring seems fine, but no movement
Yes I learnt to do that but not sure if Z can home first if its a joint axis.
The following user(s) said Thank You: Doug @ Design8Studio.com
- phillc54
- Thank you received: 2100
10 Jan 2023 05:43 #261426
by phillc54
Replied by phillc54 on topic Dual Z issue with tandem Z: wiring seems fine, but no movement
From the docs:
"The initial HOME_SEQUENCE number may be 0, 1 (or -1). The absolute value of sequence numbers must increment by one — skipping sequence numbers is not supported. If a sequence number is omitted, HOME ALL homing will stop upon completion of the last valid sequence number."
linuxcnc.org/docs/devel/html/config/ini-...l#sec:homing-section
- Doug @ Design8Studio.com
- Thank you received: 46
10 Jan 2023 12:54 #261439
by Doug @ Design8Studio.com
Replied by Doug @ Design8Studio.com on topic Dual Z issue with tandem Z: wiring seems fine, but no movement
Hey, just touching base again to say that I am getting Z to home first even though it's a joint axis.Yes I learnt to do that but not sure if Z can home first if its a joint axis.
- Thank you received: 1476
10 Jan 2023 18:37 #261476
Zero was required before the JA-merger and the multiple joint axis homing arrangement using the minus sign was added. After that zero became problematic so it's requirement was removed and its use was made optional. It was made optional rather than removing it completely to prevent breaking existing working configurations.
Replied by Todd Zuercher on topic Dual Z issue with tandem Z: wiring seems fine, but no movement
I thought the first non-negative joint needed to be a 0, then sequential. eg X = 0, Y=Y2 = -1, Z=Z2= -2
Just play with the order to see if you can home Z first in case it collides with something
The following user(s) said Thank You: tommylight, rodw, Doug @ Design8Studio.com
10 Jan 2023 19:18 #261482
What I think is now expected is that you number your homing sequence in absolute numbers starting at 1 and then add a negative sign to those which are to be homed jointly. Oh and by the way, you can also start with -1 (like me) or 0 becasue some people used to do it that way.
I find the revised docs confusing as they don't really outline how to set up your homing sequence. This machine is a bit unusual with two Joint Axis pairs.
Thanks Todd, For somebody like me who set up a Joint axis machine jast after JA was merged when nobody knew anything about JA homing, the changed procedures are quite confusing.
10 Jan 2023 21:33 - 10 Jan 2023 21:34 #261495
Isn't that what the docs say? I wouldn't know for sure whats there, I haven't read through that section for years, not since soon after the merger of JA. That said, I think all the machines I work with are still on 2.7. But if all goes as planned I will be refitting one of them to use a dual joint Y axis plus 8 extra joints to run individual Z axis on a gang router later this year. It isn't going to be like a normal multi joint axis, because each spindle joint will need to retain the ability to be operated independently and/or with the common Z each with it's own tool offset. (This is going to be fun.)
Last edit: 10 Jan 2023 21:34 by Todd Zuercher.
11 Jan 2023 01:30 #261523
Your gag router does indeed sound like fun!
In an obscure fashion as only an engineer couldIsn't that what the docs say?
- Thank you received: 7478
11 Jan 2023 02:11 #261527
) as what i gathered from that was that the numbering stay the same, just add - to tandem ones with the same number.
That was plenty of years ago, when i did the Esab retrofit, i did edit the hal and ini manually then and luckily it worked on first try!
Still working every day.
Replied by tommylight on topic Dual Z issue with tandem Z: wiring seems fine, but no movement
I must be an engineer (
- snowgoer540
- Thank you received: 907
11 Jan 2023 02:43 #261530
by snowgoer540
Replied by snowgoer540 on topic Dual Z issue with tandem Z: wiring seems fine, but no movement
For what it’s worth I’ll chime in that if you add a negative sign to a non-tandem joint’s sequence, it just prevents you from jogging that joint prior to homing.
The following user(s) said Thank You: tommylight, Doug @ Design8Studio.com
11 Jan 2023 04:24 #261534
I think I've been stuck in the old way of JA for a long time...
I have read the changed docs many times but it never bumped me out of a rut... So thanks Todd!
@snowgoer, you can also prevent jogging before homing by leaving out the kinstype=b from this ini line
KINEMATICS = trivkins coordinates=XYYZ
I removed it years ago becasue several of the GUI's could not handle jogging before homing at the time (bugs abounded, a bit like with the more recent python version transition....)
Time to create page: 0.389 seconds
