- Configuring LinuxCNC
- Basic Configuration
- Full success on my first ever CNC plasma cut! I’m beyond excited.
- Doug @ Design8Studio.com
- Thank you received: 46
17 Jan 2023 21:46 #262318
by Doug @ Design8Studio.com
Replied by Doug @ Design8Studio.com on topic Full success on my first ever CNC plasma cut! I’m beyond excited.
It seems super easy and intuitive to do material settings, with their own integrated changes to cut height and pierce height.
I'm working on understanding and doing the probe test and measuring for floating Z. I guess I need a feeler gauge set or some way to measure real world distance during the pause, so I can then compare that to the software value for pierce height, which is currently still the default 0.12. Right? If the real world distance is off, then I adjust Float Travel, if I understand it correctly.
- phillc54
- Thank you received: 2100
17 Jan 2023 23:34 #262320
by phillc54
Replied by phillc54 on topic Full success on my first ever CNC plasma cut! I’m beyond excited.
Correct.I guess I need a feeler gauge set or some way to measure real world distance during the pause, so I can then compare that to the software value for pierce height, which is currently still the default 0.12. Right? If the real world distance is off, then I adjust Float Travel, if I understand it correctly.
The following user(s) said Thank You: Doug @ Design8Studio.com
17 Jan 2023 23:49 #262321
Thanks! I made a gauge to measure, and it seems my float travel is right at 0.2" — I think I have successfully conducted a probe test and verified my pierce height. Thanks again!
