Calibration Window Not Opening
3 years 8 months ago #263504 by jlennox
Hi Guys,
I have just run into a quirky issue. Today I opened up my usual config and wanted to do some tuning of the Z axis and the calibration window no longer opens. Hal show, hal scope and all the others open fine, no errors or messages occur, just doesnt show. Just a week ago I had the calibration window showing up and working fine calibrating X and Y. Since then to now I have only edited my hal and classis ladder files. If I open up a sim config, calibration will load but show a message it cannot find any variables in the ini file so it appears to just be something I have changed in the previous week.
Anyone have recommendations on what to look for? I have compared documents from a week ago to now and nothing stands out to me that would cause this. I have attached my hal and ini file for reference.
Thanks.
3 years 8 months ago #263514 by tommylight
Start LinuxCNC from a terminal,
linuxcnc -l
That is L at the end.
Paste the error from terminal after you try opening the calibration menu.
The following user(s) said Thank You: jlennox
3 years 8 months ago #263517 by jlennox
Thanks Tommy, I'll do that tomorrow when I'm back at the machine.
3 years 8 months ago #263553 by jlennox
Hi Tommy,
Terminal gave an output saying the folder my ini file was in could not be found. As I backup my config every time I make changes, I added the data to the name of my config folder and linuxcnc did not like that. Once I removed the date from the name of my config folder so it matched the name of my ini file again, everything worked fine.
eg
Config Folder = MAZAK-VQC2040B - 29.01.23 | Ini File = MAZAK-VQC2040B.ini | Calibration will not open
Config Folder = MAZAK-VQC2040B | Ini File = MAZAK-VQC2040B.ini | Calibration opens fine
Thanks for your help Tommy, appreciate the support you guys bring. I have never started linuxcnc from the terminal before so would never of thought to try that. Good trick to add to the hat.
Cheers,
Jason
Time to create page: 0.164 seconds
