I have a hard time keeping track of all these variables, I really need to cleanup my hal
I some following interogations, I've setup a lincurve comp to offset my 6000-18000 input to a 0-18000 output which works fine, but the PWM response seems very un linear. For 0-5v out from the DAC seems to correspond to the 6000-6400rpm range and than everything above that requested speed (so 6400rpm+) results a variation from 5 to 10v (out of the DAC.
I had the same issue before adding the lincurve. any idea what might cause this?
unrelated to my spindle setup, but is there a way to setup the scale for the step gen as an expression? I have a belt setup resulting in 256000/78steps/mm or
328,205128...etc and I feel this can only cause dimensional inaccuracy
