router spindle PWM control (open loop)
3 years 8 months ago #265236 by PaulQUE
thanks for the help, I manage to get the spindle to turn on and off via the ssr, and to link the speed command to the pmwgen value. when I call for M3 S18000, hm2_7i96.0.pwmgen.00.value is set to 18000, is that normal? what's the unit for hm2_7i96.0.pwmgen.00.value? I have no output on the board, I have found that the PWM- should be connected to TB2-2 and PWM+ TB2-3; but the output is always 5V everywhere on the step4 connector, (0% duty cycle should at least be 0v regardless of the meter's sampling rate? ) I have also tried checking the signal between TB2-1 (GND) and TB2-3 (PWM+) I've included my Hal and Ini, thank you verry much for the help
3 years 8 months ago #265243 by PCW
The PWM scale parameter sets the full scale PWM value
(so if PWM scale is set to 18000 a PWM value of 18000 will result in 100% duty cycle)
I would not expect any PWM output as all the net commands that would enable
the PWM gen(or set a reasonable scale value) are commented out in the hal file
3 years 8 months ago #265245 by PaulQUE
which one are you referring to? I have the net scale and output type commented in the spindle section but they are present at the beginning of my hal file
3 years 8 months ago #265247 by PCW
OK
The PWM gen enable still seems to be unconnected
Note that you will probably want to use
the STEP- output and invert the PWM output
so that the initial PWM state is at 0V
3 years 8 months ago #265250 by PaulQUE
I added net spindle-enable => hm2_7i96.0.pwmgen.00.enable but I still get 5v between GND and step- or between step- and step +
3 years 8 months ago #265251 by PCW
Yes that's expected.
You need to invert the PWM output to use the STEP- pin:
setp hm2_7i96.0.pwmgen.00.out0.invert_output true
Time to create page: 0.076 seconds
